Question about Sony Handycam DCR-TRV140E Digital Camcorder
I own a Sony DCR-TRV260 that displays the C:31:23 error. I took a look inside by the black rollers (looking at them when the door is torward your ching, then this would make the right side roller)and found that there is a (White) plastic part that is tied to a thin metal strip that looks like is some type of spring tensioning. I am not sure where does this part is secure to or how to roll the spring to the correct tension. Also can not see the other end of this spring I can see that rolls around the left side winder.
Drawsalot
  • 38 Answers
SOURCE: error code sony dcr trv25 c:31:23
Sony says the unit needs a power reset (error 31). Unplug the camera, remove the battery and wait several minutes before re-attaching the battery and/or AC cable. Then power the camera back up. The 23 code says you need to use a InfoLithium battery-- apparently these are smart batteries that give data back to the camera. These error codes seem to be quite common however, and so a hardware issue may be the case. Some users have said that removing the battery while the camera is powered on will clear the codes. Others advocate "smacking" the camera, I would not however, recommend this. www.sony.com is a good place to look for more information.
Posted on Nov 21, 2007
ctf1800
  • 4402 Answers
SOURCE: sony DCR-PC5
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Jan 17, 2008
  • 169 Answers
SOURCE: Sony DCR-TRV140 CODE
the reel sensor is the problem of your camera...in my job as a technician i always encounter that..it is a poor connection of the sensor to the mainboard..try to clean the contact using only a pencil eraser..
Posted on Apr 13, 2008
SOURCE: C:31:23 error with DCR-PC101 Sony camcoder
Had the same error message on my TRV-720, and could not come up with a solution for weeks until I found this website:
http://www.protechcam.com/wwwboard/messages/127.html
Now the fix you will not believe, nor did I at first, but requires you to power off the unit completely and "Smack it" a few times fairly hard.
Now you may do this at your risk, but I swear it fixed mine and all the other people listed at the above web site.
I thought it was a joke - but it works!!
Good Luck!
Posted on Jul 28, 2008
welcomejee
  • 10594 Answers
SOURCE: Sondy Camcorder DCR-TRV240 rubber roller loose in tape door
See below picture and find location of small rubber roller.
Posted on Sep 25, 2008
I need the cords to plug into my DCR-TRV260 NTSC Camers to stream or hook to Computor
Go on ebay and look, I have found every kind of conceivable cable on there.
Sep 22, 2016 | Sony Handycam Digital 8 DCR-TRV260...
I have sony camcoder DCR-TRV260.I have been trying to install the software on my laptop with widow 7 but the software cannot install.it showing error. Please, how can i install the software?., so that my...
my guess is that the software is not compatible with windows 7. if that's the only pc you have, there are programs you can install to help you. this link should get you started and its from Microsoft...
http://www.microsoft.com/windows/virtual-pc/download.aspx
hope this helps
Apr 17, 2011 | Sony Handycam DCR-TRV260 Digital Camcorder
Sony handycam DCR-DVD608 Error E:61:00
I have sony handycam dcr dvd 608,when I open my handy cam,the message is showing, movie record disable
May 23, 2010 | Sony DCR-DVD608E DVD Camcorder
Hello, I have the sony dcr-trv260 and it will play back video and sound, and record sound, but will not record video. It is just black in both the lsd screen and the smaller one.
Did you examine to see if the lens cover is on?
If it is on remove it. If it is off,you need to go in the menu and select record instead of play.
Jan 30, 2010 | Sony Handycam DCR-TRV260 Digital Camcorder
On the DCR-TRV27 I don't see a black roller on Error C:31:23 on Sony trv27
It probably fail off,which is very common problem, roller should be still inside of the camcorder. You also have to look for small white, lake tubing part that hold pinch roller on the shaft.
Nov 16, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
I cannot find a driver for our DCR-TRV260.
Hello! Here is the link for your camcorder at Sony. You'll have to choose the operating system. Hope this helps!---Rick
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV260
Oct 03, 2009 | Sony Handycam DCR-TRV260 Digital Camcorder
My Sony DCR-TRV260 is not being recognised in USB
Please refer the following Link to transfer video to a computer using USB.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
Aug 13, 2009 | Sony Handycam DCR-TRV260 Digital Camcorder
Sony DCR-TRV260 NTSC
When video heads got dirty / clogged, camera gives this error.
Use good quality Video Head Cleaning tape to clean heads.
Dec 19, 2008 | Cameras
How do I download from the Sony trv260 to the computer
I am trying to find out how to download from the Sony trv260 to copy in my computer or to burn a dvd
Dec 14, 2008 | Sony Handycam DCR-TRV265E Digital...
Video camera displaying Error code C:31:23
I have been fighting the same problem. I just now picked up the camera and a small rubber roller fell out of the tape door area. I was not sure where it came from but looking closer there are 4 small rods sticking up on the right side inside the area where the tape is located. It looked like this was where the roller went so I placed it on the center rod and replaced the tape. This solved the problem and I am now able to view and recored as before. There most likely is a part that has either fell or broken off or is loose inside the tape area.
Feb 17, 2008 | Sony Handycam DCR-TRV740 Digital Camcorder
Sony Handycam DCR-TRV140E Digital Camcorder Logo
81 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
