Question about HP LaserJet 1320 Printer
Only Prints light dots on side, no error code
I have an HP Laser Jet 1320tn printer. We changed the ink cartridge out yesterday and now all it prints is very faint dots on the side of the paper. ( It was completely out of ink before we changed it yesterday) There are not any error lights blinking.
Yes, we took the strip out of the new cartridge of ink :-)
This is a network printer.
Any suggestions would be greatly appreciated. Thank you!
  • sydtibs Nov 08, 2007
    I also only get dots down one side of the paper, including when I try to print a test page. I have cleaned the print area, but still no luck.
  • Moon-Lady Nov 08, 2007
    Hello, We are going to take the cartridge back and try a new one. I will let you know if it works!
    Thank you.
I found out what was causing the problem. There is a little tab on the door of the printer that pushes in a white button. Without that button pushed in, the lever does not come down to open the cartridge and expose the drum.
As a temporary fix, I broke off the eraser from a pencil and pushed it in between the tabs to hold the white button in. This has solved the problem.
Posted on Nov 08, 2007
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Look at the chip and compare to old one, are they the same?
sometimes they upgrade or give similar chips but the "programming is bad" return as defective.
check contacts in machine are they bent?
How to reset expired hp 02 cartridge
I'm not sure what you mean by "reset" and whether you are speaking of ink jet or laser cartridges. From my experience all HP laser cartridges have a small chip (with a little circuitry) that counts down your pages and when it decides your cartridge is out of toner you cannot "reset" that chip, you can only replace it, so like when you refill the cartridge. Some of the HP laser printers let you override these toner level chips (my HP 1518ni does) but in many laser printers you are stuck when the chip counts down to '0' pages. Some printers will run if you remove the chip from the cartridge but from my experience most will not.
Ink jet cartridges are somewhat similar but I gave up on ink jet printers several years ago. I know for some brands (Epson?) you can buy a small tool that somehow resets the cartridge chip (so if you refill cartridges yourself); possibly there is something similar for HP ink jet cartridges.
Feb 13, 2015 | HP Office Equipment & Supplies
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
The orange light is lit up on the printer. What does this mean?
There is a problem with the printer. Press resume button again and see if the light orange light goes off. If not then switch off the computer wait for sometime and start again. If it still persists read the error code.
Jan 18, 2011 | HP DeskJet 940c InkJet Printer
Bypass expired message cartridge. Cartridge is less than six months old & nearly full.
Every cartridge will have its own ID and Expiry date, please check the Cartridge expiry date, if its really expired then printer will reject it even-though the cartridge is full.
We cannot bypass cartridge errors for single cartridge in INK-JET printer, because they work in TIJ technology (Thermal Ink Jet) which needs all cartridges to be functional unlike Laser-jet printers.
Jan 13, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
Hi, my printer is a HP Color Laser Jet 2605dn. I've had it for several years and it's proved to work fantastic in all areas. However, in the last few months, I've had color issues. The printer prints out...
This printer does not use ink cartridges. It is a laser printer and uses toner cartridges. Yes, one or all three toner color cartridges maybe running out of toner.
Nov 09, 2010 | HP Color LaserJet 2600n Printer
How to reset ink cartridges after refilling them
Go to the following website and download the freeware InkMonitor 2.1.2: You have to add data about new cartridge. HP60 ink cartridge information, 200 pages per cartridge. This works great for me. It gives you a history of everything printed. This way you can gauge when its time to refill your cartridges. You must refill before they run out of ink or you will burn out the print heads and have to replace them.
Mar 30, 2009 | HP Photosmart C5180 All-In-One InkJet...
Color laser printers. Costs for toner vs. initial costs for ptr
Have you thought about having your printer cartridges refilled? There are huge savings to be made in doing so and the quality can be just as good as the original cartridges (depending upon the refiller). Another option would be for you to purchase an older color laser printer such as the HP Color Laserjet 4500 or 4550. I use one myself and couldnt be happier with it. And as its an older printer, you can get the cartridges relatively cheap.
Jan 24, 2009 | Xerox 4500 Laser Printer
How to change black ink cartridge of HP Deskjet 6980
Lift the cover up.
The ink jet carriage should park in the center of the carriage.
Gently lift on the front of the ink jet until it removes. Some you have to lift up and some you have to lift down on. Just be careful.
HP inkjet cartridges tell you on the front of the stick by a dot weather it is tri color or black.
Jun 13, 2008 | HP Deskjet 6980 InkJet Photo Printer
HP LaserJet 1320 Printer Logo
80 people viewed this question
Ben Johnson
