Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
Servisafe code is not working, battery i think going down
My sevisafe was working fine for last 15 years. yesterday when i am trying to open it i put my code 0000 and showing error.
Put in correct code shows error code so wont open. The override key is inside the safe. This dummy put it in there. I know the passcode is correct. Batteries are good.
ouch.... that key needs to be kept outside the safe. when you put in the known code are you pressing A or B after it. On my safe the code is entered followed by pressing the A or B key which was not part of the code.
Jan 14, 2016 | Home Security
Worked fine put new battery in changed nothing wont work just clicks at relay box
The new battery was charged before you put it in? Or you just assumed it was charged?
When was the last time everything ran fine? yesterday, or half a year ago? because in a long period, lots of things could have corroded or just got defect.
Mar 14, 2015 | Boating
My 2008 SRS won't start and the trunk won't open. It was fine when I drove it all yesterday. I did get gas and put the 3rd row down. The radio works so I don't think it's the battery, but maybe. Any...
Turn your head lights on and try starting it if your lights dim way down or go out. try jump starting it. Your trunk release takes more power than your radio to work.
Nov 08, 2013 | Cars & Trucks
I have a servisafe already 23 years old if I loose the kee where I do another?
If you have a key right now that works, get a copy made (you might need to go to a locksmith if a hardware store doesn't have the right blank) and put it in a safe place. Safe companies will not send out keys to safes, even if they're new -- too risky.
Dec 02, 2009 | Safe International Digital Electronic Safe...
Short battery life
Use the best name brand batteries you can find. Energizers and Duracell work best. Chance the size of your pictures to the smallest you can. At 300 X 300, you can still make 8 X 10 enlargements clearly. The larger the pic, the more power it takes to process it.
Aug 09, 2009 | Canon PowerShot A570 IS Digital Camera
Acer Aspire 3680mPOwering On Problems
i think that youve over charged the battery, if you have and it still wont work i think youll have to get a new one
May 01, 2009 | Acer Aspire 3680 Laptop
Security code error
www.trycktill.com change to english from the flag at the bottom of page, security code issue helps are at the top of the page. try that, good luck.
Feb 12, 2009 | Nokia 6300 Cellular Phone
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
194 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
