Bought the bike and it was already disasambled because of ring problems bought new rings want assemble motor
SOURCE: correct timing chain marks. is a diagram available?
if the timing chain is off i dont think it would run, id suggest getting you're cams checked and reseat your valves, i have the same bike and an electronic copy of a repair manual, not for the exact same bike however. i have not been able to find the correct copy.
SOURCE: piston rings
First, be sure they actually do fit the bore. Take a ring and insert it in the bore. push the ring halfway into the bore using the piston. There should be about a 1/32" gap in the ring. Anything more than 1/16" and you need rings the next size up. If the ring won't go into the cylinder because the gap fully closes, the rings need to be a smaller size.
With the correct size rings, put them on the piston. Some pistons have an index pin in the ring groove Fit the gap to the pin. Put the piston mid-stroke and place the cylinder over the top of the piston. Squeeze the rings closed as you gently tap the cylinder downward and over the rings.
Please rate this solution. Thanks garethholleb!
SOURCE: setting timing marks on engine
Christmas is coming soon so allow me to give you a gift. Go to the site below and you can download a free PDF service manual.
http://www.carlsalter.com/motorcycle-manuals.asp
This answer deserves a top rating!
SOURCE: kick start has no compression but runs fine once i get it going
Does it feel like yhe kick is even engaging and turning the crankshaft? Are you full stroking/kicking it over or short stroking it? when cold, are you using the choke. I suggest taking a compression test when it feels as if it hs no compression It could be undersized piston, rings, or a simple. good luck
SOURCE: Yamaha VStar 1100. Valve train noise after starter clutch repair.
The cam chain has stretched a bit making it look like its half a tooth out, the tensioner takes up the slack but makes the cam timing slightly out.
You could have timed the crank 280 degrees out
It should be timed on the T mark for one cylinder & on the I mark (if there is one) for the other.
The marks before the T mark are for ignition timing (firing marks)
Good Luck
Hope this helps.
(If it does then please mark this as 'useful')
Ride Safe
Bike-Doc
Testimonial: "Thanks! Have pulled right side cover off. Front cyl cam sprocket off by half tooth. Lower sprocket off by 5 or 6!! Starting from scratch."
