Question about iLO 2600 Television
Since change to dtv, cannot get any channels. locals are 7.1, 7.2 & 7.3. tried autosearch with no luck. what do I need to do?
I cant no channels but vidos1-6 are workings
Posted on Jun 27, 2009
How to scan tv for outdoor antenna
Refer its user manual to get more details about an auto-tune function. Do it accordingly. The set will search for all available channels at that time, and will get memorized them. After autosearch function is over, it will display the first received program, and later you can select your favorite channels by Up / Dn program button on the remote control.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 24, 2014 | Vizio Televison & Video
Trying to tune tv to channel 3,but it doesnt want to stop on 3. goes all around the dial will stop on 2or4 but not on3.
Did you try to manual tune/search the channel? If you are using the autosearch/tune feature and the signal is not strong it will simply skip the channel. Find channel 3 with manual search and then save it. Good luck!
Dec 14, 2007 | Televison & Video
I'm hooking up a Nintendo 64 to a AOC LCD L32W861 television. I am trying to use an RF cable to connect the two systems. For whatever reason, the tv responds to the connection, but simply displays "No...
If you have it connected properly,it probably has to do with tv station select.Do you know how when you do a channel autosearch and it picks up cable anddigital channels?Well if you go into that menu,on my tv it shows 4 different possibilities.The first set is labeled DTV,second TV,third Cable DTV,fourth Cable.You may have to switch to the plain TV option and use channel 3 or 4 in that mode,because everything else is looking for a digital input,and N64 is not digital.I used to repair Nintendos for a full time job too.If that doesn't work,I am providing a link to N64 FAQ's and it may need repair,probably the RF cable or the RF transmitter within the console.I am thinking the TV solution will work though.
Good luck and game on! Greg
http://www.nintendo.com/consumer/systems/nintendo64/index.jsp
If you have more questions,maybe about how to set up the TV,just comment here and I will get an auto email with a link.
Aug 24, 2010 | Video Game Consoles & Games
SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1 CHANNEL WORK WHEN YOU CHANGE TO TV CHANNELS 1 - 5 BUT DOES NOT WORK ON DTV CANT CHANGE JUST FROZEN ON CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Dec 26, 2009 | Televison & Video
I'm able to view all local channel in digital (new tv with in philip hdtv indoor antena) but after conver to diggital I lost channel 7 and 9 I scan many time but sitll no lick
What local area are you in? 7 & 9 may have moved to another channel. Every distributor of channels ie. Comcast, Directtv, Dish, Bright House, etc has channels all over the map!! with no real clear plan it seems! If you go to DTV answers.com you can get the new local lineup for your area. At this point, if you still don't have the signal, you may need to re-align your antenna for the best possible reception. If you go to Terk.com you can type in your zipcode and it will show you where the transmitting antennas are located. You may need a better antenna like a Wineguard or larger Terk to get all your channels. Hope this helps
Jun 23, 2009 | Insignia Digital-to-Analog Converter for...
Sudden no signal on digital channels on a Vizio VX37L
Your cable signals are probably encoded so that you have to use their cable box for reception. Renders your tv tuner useless used for OTA.
Aug 28, 2017 | Vizio VX37L Television
I cannot get a signal with converter box and Philips indoor antenna
Try to manually enter the local DTV Station Channels, instead of letting the converter scan for channels. And try moving the antenna and then re-entering the DTV channel.
You should really have an external antenna that is matched to your local reception needs.
contact your local TV stations, their engineers will be more than happy to help.
Jun 15, 2009 | Durabrand DWT1304 13" TV
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
DTV connection
Have you tried http://www.antennaweb.org/aw/Address.aspx? This will show you the location of the HD broadcast towers for your local stations and my recommendation would be to use an outdoor antenna if you can. Picking up the reception is definitely about pointing the antenna in the direction of the towers.
Nov 10, 2008 | Televison & Video
Televison & Video Logo
165 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
