Question about Microsoft Windows XP Home Edition
Unable to install avg8 free in windows 2000 prof sp-4
When i try to install avg free version 8 it does not install it shows a error some thing wrong happened in c/document & setting/admi/local setting/temp/avg8inst.err.
when i restart my system one error message come for every time like userinit.exe saved a error avg8inst.err in c/document & setting/admi/local setting/temp so restart the system.
but system is ok working fine,but i am unable to install avg only other s/w install properly.
if any one solve this problem really thankful for that persion.
my no-09705741406
  • j0llyc
    j0llyc May 11, 2010
    Have you tried to uninstall AVG in safe mode?
    If not try that or even perhaps run a registry cleaning program.
    Let me know.
    Regards,
    Chris
    Brigadier General:
  • 7,191 Answers
Instead of installing AVG free, download & install Avira Antivir Personal Free. It is better compared to AVG in terms of virus detection 7 also very light on the system.
To download click here:
http://www.free-av.de/en/trialpay_download/1/avira_antivir_personal__free_antivirus.html
Posted on Jun 27, 2009
Removal of AVG8
Try bootin to safe mode by pressing F8 on turning on the system then try to uninstall by going into the control panel [Programs(vista)/Add or Remove Programs(XP)]
By doing this you will be able to uninstall the AVG anti virus.
Then restart and the system will boot in normal mode then install Kaspersky. Never have 2 anti virus in a system. Just a word of caution.
Cheers !
Aug 29, 2009 | Acer Aspire 3000 Notebook
My AVG is conflicting with my installing Kaspersky.
you might not have uninstalled AVG .instead you could have deleted the AVG folder.
AVg components are still there in the registry.if you didnt uninstall it ,install AVG once more and uninstall it manually.
if its not working remove AVG components from registry
here are the instrucions:
To remove the AVG registry entries, open Registry Editor (Start-> Run-> Regedit). In the registry editor, navigate to the entries mentioned below,
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG6INSTALL
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\AVG\Avg8
Right click on these entries and then delete them. If you are not comfortable about deleting registry entries, you can use a free registry cleaner. If you are using a 64 bit machine, then these are the entries to be removed.
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG7Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG6INSTALL
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\AVG8Uninstall
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\AVG\Avg8
Once these entries are removed, Kaspersky installation will be completed normally. Alternatively you can also use the AVG cleaner or Kaspersky removal tool for AVG8.
Jul 21, 2009 | Microsoft Windows XP Home Edition
Trying to download avg 8.5 free edition
You cant put 2k service packs on XP, try xp's sp3, it may solve the problem
May 20, 2009 | Microsoft Windows XP Home Edition for PC
Uninstall avg8 antivirus
it's an odd solution but it does work.... you have to reinstall avg 8.... then uninstall it.
Apr 16, 2009 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
I cant get rid of this error its on avg 8 its a back up file
You need to uninstall and then re-install AVG.
Go to this link to get the AVG removal tool:
http://www.avg.com/download-tools
Mar 13, 2009 | Systemax Ascent RTS A14 (980796) PC...
How to uninstal avg 7.5 ?
try to download the avg8 from here and install it. then if you want to uninstall run uninstaller from controlpanel for avg8.
the avg8 should be able to remove avg7
Feb 24, 2009 | Microsoft Windows XP Professional With...
Completly Uninstalling AVG8 Free edition
hi..still you might not have deleted some of the
folders,that's why you are not able to install it.
uninstall it completely.
check it out..
thank u..
rate me..
Feb 24, 2009 | Dell Dimension E520 PC Desktop
AVG Free install fails
Install AVG8.0, it should fix your problem
Feb 10, 2009 | HP Pavilion dv6000z Notebook
Unable to install AVG 8 free
Strippy had asked you a right question. You may be trying to install AVG when you have already one antivirus program running. OR you had once installed AVG sometimes in the past, but uninstallation was not properly done. Hence it is showing registry key error.
1. If you are running any anitvirus prog now, first uninstall it. Then restart the machine.
2. Now you try install AVG. it should install. if not, try the following
Go to system restore and create restore point for safety.
go to run and type regedit and then enter
Press cntrl + F for finding earlier registry keys of AVG. Try to find out all old registry keys amd delete them all.
Restart the machine. Its DONE.
Jan 15, 2009 | Microsoft Windows XP Home Edition
Uninstal AVG 8
GO TO CONTROL PANEL ON YOUR PC AND LOCATE ADD AND REMOVE PROGRAMM THEN CLICK ON THE APPLICATION YOU WANT TO UNINSTALL THEN UNINSTALL IT AFTER THAT GO TO YOUR HARD DISK DRIVE C LOCATE PROGRAMM FILES THEN OPEN IT AND LOCATE FILE OF AVG8 AND DELETE IT BUT YOU MOST FIRST UNINSTALL FROM CONTROL PANEL BEFOR DELETING THE FILE. HOW TO GO TO CONTROL PANEL, CLICK ON START MENU LOCATE CONTROL PANEL CLICK ON IT THEN LOCATE ADD OR REMOVE PROGRAMM AND CLICK ON IT WHEN OPEN CLICK ON THE PROGRAMM NAME YOU WANT TO REMOVE AND AT THE RIGHT HAND SIDE YOU WILL FIND (CHANGE/REMOVE) CLICK THEN YOU FOLOW THE INSTRUCTIONS. AFTER FINISH THE UN-INSTALL YOU CAN INSTALL THE NEW ANTI-VIRUS
Nov 20, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
129 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
