Question about Beko 24 in. D3731F Free-standing Dishwasher
Beko dishwasher fills with water but then the pump doesn't kick in
    Scholar:
  • 123 Answers
Hi there...this apliance emloys a flow meter..somtimes called a water meter...it is located on the bottom left hand side of the appliance it is accessible on removal of the left hand cabinet panel...disconnect and reconnect the plug to it...if this fails change the flow meter
regards Sir Galahad
Posted on Aug 25, 2009
Beko dishwasher doesn always fill with water but makes sounds as if it does. Other times it works great any ideas?
depending on chosen wash cycle washers are not always supposed to 'fill' just use enough for that cycle .
If you mean sometimes no water at all and sometimes water with same settings check hoses and valves .
make sure valves are fully open hoses securely attached and hoses from valves to washer are not pinched twisted or damaged.
Hopefully the water not getting in the washer isn't leaking all over your floor below the washer.
Jul 18, 2016 | Beko Dishwashers
Why beko dishwasher wont fill with water
Assuming you can select programs and start it, the most likely problem is water inlet valve. Make sure the water tap under kitchen sink is open.
The water inlet valve looks like this.
Beko DS1054S Solenoid Valve
Sep 03, 2014 | Beko DS1054S 450 mm Silver Freestanding...
I have beko dishwasher works fine but no hot water is it just the element which needs replacing or could it another problem MODEL DWD4310S
How far is your water heater from your dishwasher. I knew someone who had to get a circulating pump. His dishwasher was so far form the water heater so when the dishwasher would fill, it used the cold water that is sitting in the pipes and by the time the hot water got there, the dishwasher didn't need any more water. the pump will keep the water circulating back and forth to and from the hto water heater. Or you an get one of those electric small heaters that heat on the spot as well.
Dec 10, 2009 | Beko Dishwashers
My beko eco care d3421fw dishwasher won't fil with
i have beko glacier fridge freezer.the freezer section works as normal but the fridge section only works sometimes.the pump only starts after you hear a click sound from the back of the fridge.is there a starter component that activates the pump.
May 22, 2009 | Beko 24 in. D3421F Free-standing...
Beko dishwasher wont start it comes on wont fill up
hi there...have you checked the water supply to the dishwasher.......sounds either no water to the appliance or a faulty water inlet valve to the appliance
regards Sir Galahad
May 15, 2009 | Beko 24 in. D3421F Free-standing...
Push start button fills with 2in of water then does nothing
hi there........this fault is usually associated with a faulty flow meter....situated on the lower left hand side of the apliance and is only accessible on removal of the left hand cabinet panel
regards Sir Galahad
Apr 15, 2009 | Beko 24 in. D3421F Free-standing...
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Beko 24 in. D3731F Free-standing Dishwasher Logo
504 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Marvin
Marvin
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
