Question about Poulan WeedEater Hedge Trimmer 25cc Engine
Engine runs but the trimmer blades wont engage
Need help on how to make the trimmer blades go back and forth while I have the engine running consistently. thank you, mike
  • 59 Answers
On the back of the trimmer there is a plat take it off and see if the cam is working around and around
Posted on Jun 27, 2009
Blades do not move when engine running on hs45 sthil
Look for grease Zerk
xxxxxxxxxxxxxxxxxxxxx
May 20, 2014 | Stihl Garden
Blade on a Craftsman 20 in bushwacker electric hedge trimmer stuck on a vine and will not engage
with engine off ! use a pocket knife to whittle wood branch out of bar , do not yank it off the bush the blade will bend then will become stuck
Mar 10, 2013 | Craftsman 20 in. Hedge Trimmer
Neuton cordless hedge trimmer may need new motor. the blade does not go back and forth
Primary gear on motor shaft may be stripped, no source for replacement known. I have the same problem motor runs but blades do not move.
Feb 19, 2012 | Black & Decker Garden
The trimmer on my Braun 1775 FreeControl shaver has stopped working. When it is engaged, the pitch (sound) of the shaver changes in the usual way with the usual increase in vibration. However the trimmer...
The trimmer is either broken or clogged up with a combination of shavings and skin oil. If it is broken, there are no replacements available. If it is clogged, you can fix it by thoroughly cleaning it. Dip the blades of the trimmer into some rubbing alcohol or other mild solvent type liquid. Soak it for about one minute. Then take an old toothbrush and firmly scrub the teeth. Then turn it on and it should free it up. If it still doesn't move you can advance the blade manually to get it 'unstuck'. One of the blades is fix and the other moves back and forth. You should be able to see which one is supposed to move by sight. Take a small flat screwdriver or similar object and push the blade to each side once. Turn it on and it should move freely. Dip the trimmer blades back in the rubbing alcohol while it is running and let it run for about 15 seconds.
If still not working it is beyond repair. The easiest and least expensive way to get working again would be to purchase a new ;lower unit' which includes the trimmer. You will find at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-1775-freecontrol-lower-unit-p-828.html
Aug 24, 2011 | Braun FreeControl 1775 Hair Trimmer
The engine starts up and runs perfectly but the blades are not molving.
Check the gearbox for lubrication, if it hasn't gotten any grase for a long time the bearings may have failed.
If you feel adventurous remove the bottom cover and look, there should be a bearing at the motor output, and at the blade connection, the bar that connects the two and makes that back and forth action should be connected to both ends.
Jun 14, 2010 | Craftsman 22" Gas Hedge Trimmer
Blades not moving on ss24 weedeater
I just disassembled a SS24 hedge trimmer that had the same problem of the blades not moving. The problem is that there are 2 or 3 teeth on the helical gear that are missing. Consequently, the small gear on the motor shaft cannot continuously engage the gear that moves the blades back and forth.
May 27, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Sideburn trimmer does not cut anymore but still makes noise. trimmer blade does not move.
It is pretty common for the trimmer to get jammed up with hair particles and skin oils which can prevent the blade from moving.
Try running the blades of the trimmer in a shallow dish of rubbing alcohol. Then clean the blades vigorously with an old toothbrush or similar. If the blades still does not move try using the tip of a small flat screwdriver or similar object to push and advance the moveable blade. Repeat running in alcohol and brush clean
If this doesnt work, you will probably need a new trimmer
Apr 15, 2010 | Braun 360° Complete 8985 Electric Shaver
A5 Golden Oster trimmer
alignment is of and blade needs cleaning and oiling
Dec 19, 2009 | Health & Beauty
NEED Homelite UT40502 manual
Homelite UT40502 gas hedge trimmer, engine runs fine but
cutting blade will not move back and forth.
Sep 21, 2009 | Homelite Garden
Engine dies when blades are engaged
sounds like one of the safetey switches are not working
Mar 22, 2009 | Poulan/Weed Eater No. 5000p 952711612 Pole...
Poulan WeedEater Hedge Trimmer 25cc Engine Logo
454 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
