Question about Sunpak Auto 555 TTL Flash
Won't flash when connected to my Nikon D80???
The flash fires everytime I hit the test button on or off the camera but will not even let me take a picture when its attached to my Nikon D80. What could I be doing wrong?
    Novelist:
  • 181 Answers
Set the settings to TTL for both the camera and the flash
Posted on Jan 04, 2010
Everything on control panel is flashing. Can't operate camera.
Hi Shirley,
It sounds like your camera's CPU is stuck in a loop. First, I'd remove and transfer any pictures on the SD card in a card reader connected to your computer, followed by formatting the card. Leave the SD card out of the D80. Set the power switch on the D80 to "off" and install a freshly charged battery. If it is still flashing, a "Full Reset" may help.
Nikon recommends that a full reset be done only under direction of Nikon staff. The procedure is outlined along with graphics on this page under "Full reset". I suggest calling Nikon support to see if they think this procedure (or maybe another that they have) will solve the problem.
Nikon Technical Support
8AM - 12AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
Jan 09, 2013 | Nikon D80 Body Only Digital Camera
Cannot fire shutter on d80
Hi, Have you cleaned the lens' electrical contacts?or is the lens connected loosely?? Examine but probably little need to clean the camera's electric contacts considering its' young age. Do you have access to another AF body on which you can test the lens and another AF lens to test the D80? Do the following things 1.take a dust free eraser and clean the contacts on the camera carefully by keeping it upside down to prevent dust going inside. 2.do the same for lens contacts. re-attach the lens firmly. hope this solves your probs. regards sreejith
Jun 13, 2007 | Nikon D80 Digital Camera with 18-135mm...
Compatability of Speedlite 300TL on Nikon D80
The Canon 300TL will work with the Nikon D80, though you won't get all of their features, such as iTTL metering.
Mar 05, 2012 | Nikon Cameras
I want to use my nikon d80 with my sb600 and as a infrared remote
The Nikon D80's shutter can be released via handheld "IR" or infrared remote. You can buy them online or in most camera shops. The Nikon branded one will cost the most, but really doesn't perform a whole lot better than the $5 third party versions. The nice thing about IR remotes is that only a transmitter is needed. There's a built in IR receiver on the front of the camera body, and as long as it is not obstructed - or too far from the transmitter, it will work fine.
The SB600 will fire if setup to work correctly when the shutter is released "normally" - triggering with a IR remote will not affect the SB600 flash whether mounted on the camera or if in "commander mode". The D80 manual has details on pg 38 to operate in both the instant and time delayed IR operation modes and should be consulted as Nikon does not allow copy and paste from the manual - and they make use of graphics for button functions.
When distances are too great for the IR remote, you'll need to go the route of an RF or radio frequency remote instead. Many of these will work at distance up to and even beyond 100 yards. They consist of a transmitter and receiver. The receiver can be mounted on the hot shoe of the camera or tethered via cable to the camera body. This is not the question you asked about, so I won't go into further detail - but only mention it as another way of doing the same thing from greater distances or when you can not be in front of the camera to access the IR receiver on the D80 body.
If this was helpful, please rate it as such. Thanks and good luck!
Sep 29, 2011 | Nikon D80 and 18-55mm Lens Kit Digital...
I have a Nikon D80 and I hit the open flash and now it won't flash. The flash will pop up but won't flash.
Contact your local Nikon authorized service center for repair on this issue. If you're in the east coast or in the New York City area you can contact us for this.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 06, 2011 | Nikon D80 Digital Camera
My nikon D80 built-in flash not work in TTL mode
It may be sensing enough light at your location so the flash does not fire. If you want to force it to fire, make sure the flash icon is selected and also use Auto mode to test
Nov 27, 2009 | Nikon D80 Digital Camera with 18-135mm...
D80 "battery drained' and "F"sign when pressing release button
Pls make sure of the following:
- You are using original Nikon batteries (generic batteries gave a similar problem to me)
- The aperture ring of your camera is correctly placed
Nov 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 flash won't pop up
Must be a problem with the flash lock. Try to pop up the flash manually using the flash button located at the top left of the camera beside the flash. If this does not work, you may need to have the cam serviced
Jun 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80. Vivitar 4600 Flash unit
That particular unit is probably not a good choice for the D80 because the trigger voltage (the electricity which flows from the flash through the camera circuits to fire the flash) is 19.5 volts, according to http://www.botzilla.com/photo/strobeVolts.html - this could possibly damage your camera electronics.
You don't have to stick with Nikon brand Speedlights, but get a modern flash which says it is I-TTL compatible for Nikon.
Jan 01, 2009 | Vivitar 850AF for Nikon TTL Flash
Nikon D80 using Bower AF 724AFN
I also purchased a Bower 724AFN to use with my D80, and experience the same problems. Received confirmation from Nikon that this flash unit is not compatible with the camera. I then purchased an SB-600 flash, and haven't looked back. It's worth the extra money for this high quality unit; fully compatible, and compliments the TTL features of the D80. I'll never deviate from original Nikon accessories again.
May 22, 2008 | Bower (724AFN) for Nikon Flash
Sunpak Auto 555 TTL Flash Logo
216 people viewed this question
Top Sunpak Cameras Experts
bhargav
Tony Parsons
Tony Parsons
Neal Marrison
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
