Question about Kodak EasyShare V610 Digital Camera
Kodak v610 camera shows error #E45 - Kodak EasyShare V610 Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 09, 2010
Camera opens with optical zoom in mid range. Will not move to W..
HI! I HAVE A PROBLEM WITH MY CAMERA KODAK V610. WHEN I OPEN IT, THE LCD SCREEN APPEARED (CAMERA ERROR # E45 AND SEE USER'S GUIDE...PLEASE HELP ME HOW TO FIX IT...I LOVE MY CAMERA SO MUCH...I HAVE SOMETHING SENTIMENTAL VALUE FOR MYSELF....I KEEP IT FOR HOW MANY YEARS...I DON'T WHAT TO DO???? I LOOK FOR THE USER GUIDE IT WASN'T THERE...HOPE TO HEAR YOU SOON. THANKS
Aug 21, 2013 | Kodak EasyShare V610 Digital Camera
Error # e45
Hello, Unit needs serviced !!!!
Dec 01, 2012 | Kodak EasyShare V610 Digital Camera
Kodak v610 error#E45. What to do?
When you pull the battery out and when I shut it off, the error code will remain. Try removing the SD card and turned it on, it worked when I tried that.
Sep 20, 2011 | Cameras
Error message E45 comes up on camera - What can I do to fix it? Kodak easyshare V610. Message comes up when camera turned on. Batttery charged etc.
Is the lens extended? If so, try hitting the lens a couple of times with the palm of your hand and then turning off the camera. Turn it back on and let me know what happens. Sounds crazy I know, but those things are notorious for that error and that problem. You can also try taking out the SD card and see if the error goes away. Let me know what happens. Thanks.
Jeff
Nov 23, 2010 | Kodak EasyShare V610 Digital Camera
Camera error #e45 kodak digital camera v610
Hello :
This means the lens alignment of your camera is messed up and it will take repair service to fix it. The cost of this might be equivalent to replacing the camera- Better to call KODAK and see what they're willing to do for you.
Not supported solution is to smack the side of the camera . That helped some people with the same error .
Please read this useful link carefully : Kodak cam errors forum
I hope this will help .
please don't forget to rate !
Apr 06, 2010 | Kodak EasyShare V610 Digital Camera
I have problem with e45. kodak
This is a lens fault.
This model is no onger repaired. If in warranty KODAK will exchange to a M420. If not in warranty you can chose the Trade up option where KODAK trades you old camera for a new camera for 25-60% cheaper than the listed price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 17, 2009 | Kodak EasyShare V610 Digital Camera
E45
"E45" appears on your camera's display when your camera requires service or repair. It also something to do with your camera lens
**Kodak support line at 1 800 235 6325 (23KODAK) or visit the website www.kodak.com/go/stepbystep
Error #E45
For this problem try the following:
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Oct 02, 2009 | Kodak EasyShare V610 Digital Camera
V610 KODAK ERROR E45
This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. If charging/replacing the batteries does not clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Dec 04, 2008 | Kodak EasyShare V610 Digital Camera
Kodak EasyShare V610 Digital Camera Logo
987 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
