Question about HP Compaq nc8000 Notebook
White line on my notebook display...
In one moment ijust saw it apeear white line (1 mm) from top to bottom of the screen...i restsrt pc .... but its still there...what to do ? whats this ....
  • Anonymous Mar 14, 2014
    display unavailableor some time it apeear lines or waves on screen
    Problem Solver:
  • 11 Answers
Your monitor is dying. It needs to be replaced
Posted on Jun 27, 2009
White 1 in. Bar running from top to bottom of screen
Plug in external monitor to see how that works. If it does same the issue is with your laptop. If it works fine the issue is with your laptop display that needs replacement.
Aug 31, 2017 | Toshiba Satellite M65-S909 (PSM60U02W021)...
White lines appearing on my Nokia E66's Display
Sounds like the display circuit. You'll need to replace the LCD screen. You can purchase one here www.fix-lcd-screen.com for about $17. Also quite a few YouTube videos on repairs for tis phone.
Feb 01, 2013 | Cell Phones
White-line on my lap's lcd
It does sound like a problem with your screen. If you want to get it fixed, a good company called revivemylaptop have an offer on at the moment. (www.revivemylaptop.com)
Jun 08, 2010 | Acer Aspire 4720 Notebook
We have a hp pavillion dv7-1240us & we need directions on how to replace the screen ???
LCD Panel removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery, wireless LAN Minicard, keyboard, switch cover, display panel, display bezel, and inverter.
  1. Remove the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
  2. Remove the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Lift the LCD panel out of the display panel enclosure.
LCD Panel replacement Note: Before replacing the LCD panel, remove the left and right hinges from the old LCD panel and install them on the new LCD panel.
  1. Place the LCD panel into the display panel enclosure.
  2. Replace the two 4 mm P1 Phillips-head screws that secure the metal tabs on the bottom center edge of the LCD panel to the display panel enclosure.
  3. Replace the four 4 mm P1 Phillips-head screws that secure the hinges to the display panel enclosure.
To remove in order to replace LCD, you will have to remove WLAN, keyboardwith the instruction :
Wireless LAN Minicard removal Caution! Observe all precautions when removing and replacing components.
Before you begin: Remove the battery.
  1. Loosen the two captive P1 Phillips-head screws that secure the memory/wireless LAN Minicard cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the edge of the memory/wireless LAN Minicard cover and remove it.
  3. Carefully disconnect the wireless antenna cables from the wireless LAN Minicard with a small needlenose pliers or tweezers.
    Important! Use care when disconnecting the wireless antenna cables from the wireless LAN Minicard. Damaged cables or connectors can degrade notebook performance.
    Note: If three antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to terminal 1, the cable labeled 2 connects to terminal 2, and the cable labeled 3 connects to terminal 3. If two antenna cables are connected to the wireless LAN Minicard, the cable labeled 1 connects to the MAIN terminal and the cable labeled 2 connects to the AUX terminal.
  4. Remove the two 3 mm P1 Phillips-head screws that secure the wireless LAN Minicard to the system board and allow it to release to the spring tension position.
  5. Grasp the wireless LAN Minicard by the edges and pull gently to remove it.
  6. Place the wireless LAN Minicard in a static dissipative bag.
Keyboard removal Caution! Observe all precautions when removing and replacing components.
  3. Remove the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  4. Remove the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  5. Turn the notebook right side up and open the display panel fully.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and slide the keyboard toward the rear of the notebook.
  7. Using minimal force, push the locking bar toward the rear of the notebook to unlock the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the ZIF connector and ribbon cable.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. Place the keyboard right side up on the top cover and insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the keyboard ribbon cable.
  2. Push the locking bar toward the front of the notebook to lock the keyboard ZIF connector on the system board.
  3. Toe the tabs on the bottom edge of the keyboard into the top cover.
  4. Press the keyboard flat.
  5. Close the display panel and turn the notebook upside down.
  6. Replace the 8 mm P1 Phillips-head screw in the memory/wireless LAN Minicard compartment that secures the keyboard to the base enclosure.
  7. Replace the two 8 mm P1 Phillips-head screws that secure the keyboard to the base enclosure.
  8. Toe the memory/wireless LAN Minicard cover into the base enclosure.
  9. Tighten the two captive P1 Phillips-head screws.
May 17, 2009 | HP Computers & Internet
White vertical line on my hp compaq nc8000 monitor
Hi there welcome on fixya.com!
Try another screen and tell me if you still have the line !
Apr 04, 2009 | Compaq NC8000 Notebook
The bottom part of my laptop screen have colour lines
You need to change the display screen of your laptop. Walk into HP shop anywhere.
Mar 17, 2009 | Computers & Internet
Lcd display
Try connecting your laptop to an external monitor.Connect it with a vga cable to your monitor and press Fn+ monitor key(I don't know what it is for acer) to switch displays.If there are no lines on the external monitor then the problem is due to the notebook lcd.If there are lines then it is due to a driver.Reinstalling the driver should fix that then.
Aug 24, 2008 | Acer Aspire 4315 Notebook
Line in my lc screen
A line from top to bottom or side to side is a dead or failed pixel sensor. There are hundreds of pixel sensors at the edges of the screen, when one fails it causes a line, the line can be red, blue, white, or black. Unfortunately, there is no way of repairing the line, other that replacing the screen.
Jul 29, 2008 | Compaq Presario 700 470024-192 Notebook
MacBook opening screen leaves a one inch black strip on both sides.
use the gray bar on top to move the screen to the upper left hand corner.  Then click and drag the bottom right portion of the screen to the size that you want it be.
Mar 21, 2008 | Apple MacBook PC Notebook
Vertical lines on my laptop screen
white vertical line on my screen of my laptop..how can i fix t
Oct 26, 2007 | Compaq Presario M2000 Notebook
HP Compaq nc8000 Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
