Question about HP LaserJet 2820 Printer
The printer prints on right hand side while left hand side is blank
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 127 Answers
Reinstall the printer driver, for starters. failing that take the toner cartridge out, give it a gentle shake end-to-end so that the toner powder inside is fluffed up, and then put it back. You may need to change the cartridge completely. HP lasers are usually pretty good.
Posted on Jun 27, 2009
Can Lexmark x2470 scan and print a double sided document?
after reading the manual, http://www.lexmark.com/publications/pdfs/2007/2400/ug_en.pdf, yes it is possible - not that it tells you how to do it though so read on.
Until you become familiar with the process just use one sheet of paper at a time in the printer.
As you know, in the scanner the top right of your document goes to the right hand front corner of the scan bed (the clear window), place the page on the scanner and scan.
Pick up the printed sheet of paper and flip it so the left hand side edge is now in your right hand and the right hand edge is now in your left hand and you are now looking at the blank side of the paper.
Insert the page back into the sheetfeeder.
Flip the page to copy in the scanner so the rearmost edge of the paper is now to the front of the scan bed and the front edge of the paper is now towards the rear (you should now be looking at the page you scanned previously).
Scan the page.
you should have now scanned both sides of one sheet of paper to another sheet of paper.
as your printer does not have a sheet feeder for the scanner you have to do the process manually. hope this helps.
Apr 20, 2011 | Lexmark X2470 All-In-One InkJet Printer
Ricoh 1224c prints on left side only - Blank on right side
well if its just on the black then it might be the black drum see if it does the same on the color from copying and printing. If it does the same in color then its not the drums it may be the developers, but you wont know untill you test the color if it only happens in black and white its definitely a problem with the drum.
Mar 25, 2010 | Ricoh Aficio 1232C Color Copier
I have an hp laser printer 2550. all os a sudden
What has wrong is the toner cartridge holder has jumped a tooth and thats what is causing it. It is a easy fix but very hard to tell you over fixya. Steven 818-888-0006
Mar 12, 2010 | HP Color LaserJet 2550n printer + HP Color...
My psc 2210xi sends out several blank sheets prior to printed sheets when I'm printing something from the web. Sometimes, it never prints from the web . . . just shoots out 4 blank sheets. Thx.
u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can see there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next
3.select the port usb virtual 001 for usb connection and select lpt 1 for wireless, click on next
4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer [it is a generic driver fot hp's printer]
6.click next use this printer as a default one
7.it will give u an option to print a test page
8.click on "no" and hit next
9.now try to print and check
Nov 09, 2009 | HP PSC 2210 All-In-One InkJet Printer
Print on left hand side of page is faded as you look to the middle and right hand side of page print is clear
Place one hand either side if printer,
Gently shake the printer left and right a few times without lifting it off the desk..
What happens is that when a laser printer is moved and is not kept level the toner will move to one side or the other, the gentle shake evens out the toner.
Jul 01, 2009 | Canon LBP3200 Laser Printer
Whenever I try to print out a word document only half of it ever comes out ( the left hand side ) but the right hand side is completely blank. Is this likely to indicate a printer problem or the way the...
Try to change text orientation form portrait to landscape.If the black is on the same side of the text problem is on the document, if black is on the same side of the paper problem is on the printer.
Sep 25, 2008 | Office Equipment & Supplies
Envelope Printing on HP 5610
Installed SR-3 from Office Word. It did the trick.
Mar 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Epson Rx420
Click Start - Printers and faxes
Right click on the printer icon and select properties.
Click on Advanced tab. Enable the option print directly to printer.
Click apply n OK.
Check for the result.
Dec 22, 2007 | Epson Stylus 1400 InkJet Photo Printer
140XiIII left side print right side completely blank
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
Jun 30, 2007 | Zebra 140XiIII Plus Thermal Label Printer
HP LaserJet 2820 Printer Logo
138 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
