The printer will not take up photo paper of any thickness.
SOURCE: Rollpaper feeding problem on R800 Epson
try to look at your rollers made of black rubber, if they are shining then they need cleaning, if you know how to open the unit to get to all these rollers then you might be able clean them yourself with laquer thinner and a rag, where gloves and turn the rollers into the soaked rag and keep turning tight with lots of elbow grease until all rollers lost that shine.
SOURCE: Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
SOURCE: printer paper will not feed into the printer
Your printer has a photo switch at paper feed section, this switch is triggered when there is paper and vise versa when there is none, check to see if there is/are some torn pieces of paper blocking or clogging the plastic lever from triggering the switch. A torchlight and a plastic pair of tweezers will help a lot.
SOURCE: epson stylus pohoto 830u paper feed
I'm afraid this series of printer (810 -830) doesn't handle heavy photo paper well - which is a bit strange for a so-called photo printer. If you hold each sheet and help it to feed it will work. But ...... for goodness sake. Your best bet is to sell it on e-bay and buy something that will handle heavy paper.
SOURCE: printer will not feed card stock
Sorry. I have not solved this problem and I cannot afford to pay anything for your services.
