Question about Amana Refrigerators
Maytag model # BC20TL bottom freezer. Compressor
Maytag model # BC20TL bottom freezer. Compressor is running 100% of the time. Everything is melting.
maklean
  • 1665 Answers
SOURCE: Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas.
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer.
Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
Watch its operation more closely to see if any same symptom.
Posted on Jan 15, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    tborn6
    • 700 Answers
    SOURCE: Fan running,both cold settings at 4 , freezer 14 degrees C
    you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
    Posted on Mar 28, 2009
    philbran
    • 242 Answers
    SOURCE: Maytag Bottom Freezer MBB2256GES not cooling
    you must change out the relay to find out if the compressor is locked , but before this is done let the compressor cool to room temp. then try again.
    Phil
    Posted on Jun 10, 2009
    • 72 Answers
    SOURCE: Our freezer is not cold, food is defrosting, ice
    Look at the back of the freezer wall from inside the freezer. Is there frost on it? If there is, you need to replace one of the components of the defrost system. If there is no frost then you need to have a repair made to the sealed system, it is either out of gas or the compressor is running inefficiently
    Posted on Jun 20, 2009
    Maytag side by side refrigerator - refrigerator and freezer both not cooling.
    I had same issue , required a new compressor and regas. All cooling for fridge side is blown in from freezer
    Jan 25, 2013 | Maytag Refrigerators
    I DO NOT KNOW HOW TO ADJUST TEMP. ON FREEZER AND REFRIG. EVERYTHING IS MELTING. MODEL # MFI 2568AEQ PLEASE HURRY
    Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
    If your refrigerator is running but warm, then...
    Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
    Refrigerator Condenser Coil Cleaning Refrigerator Repair
    Refrigerator Troubleshooting Refrigerator Compressor
    Refrigerator Compressor Start Capacitor and Start Relay
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    Aug 13, 2011 | Maytag Refrigerators
    I have a maytag mft1972hr Water leaking out of my freezer door, everything almost defrosted, ice almost fully melted, Freezer temp 32 degrees F and frig temp 42
    heatman101
    Jun 01, 2011 | Maytag Refrigerators
    Maytag Model MBB2254GEW, bottom freezer: intermittently freezes and do not always feel cool air coming through the fridge. This is on and off for the last few months, where we find ice cubes all melted...
    heatman101
    May 24, 2011 | Maytag 21.9 Cu. Ft. Bottom-Mount...
    We have a Maytag refrigerator with a bottom freezer. The freezer is not getting cold. The fan is working and it makes a humming noice sometimes but all the food was melting. What could be the problem?...
    Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
    Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
    heatman101
    Oct 11, 2010 | Maytag Refrigerators
    We have MAYTAG model #RSW24 , for last month we are having continuous water dipping from freezer bottom basket place. After checking everthing looks normal, yet water leakage didnt stop .Your advice is...
    I had the same problem. The fix was to remove the freezer baskets and defrost the trough behind the back panel wall at the bottom of the freezer section with a hair dryer. This trough takes melted ice created by the auto defrost cycle out the freezer section through a small rubber tube drain into a pan located underneath the refrigerator. My first effort was not successful but the second time I did it it worked. In addition to defrosting with the hairdryer the second time, I also blew out the rubber drain line with a small air compressor. This solved the problem and I have not had a freeze up for the past 6 months.
    Jun 28, 2010 | Maytag MZD2766GES Side by Side...
    Ice build up on bottom freezer
    Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
    Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
    Everything in the freezer has defrosted, temp setting at 6 (refrigerator compartment at 5). Amana bottom freezer model ARB210AB Water will not freeze, ice cream melted and frozen veggies and meat have...
    Is there frost on the freezer panel? are the two motor and compressor running (freezer motor and condenser motor)? find this out 1st. this is nothing you did but if you are not mechanically incline at this point only a frig tech can properly check and tell you exactly what is it. theres are the things it might be...
    compressor not working
    condenser not running
    freezer fan not running
    thermostat not sensing temp.
    stuck in defrost
    heaters on too long
    bi-metal shorted
    timer not working
    now if you paid alot for this frig at least get someone to look at it for a service call ($40-60) if it too high to repair then its time to get a new one
    Mar 27, 2010 | Amana Easy Reach Bottom Freezer 20.5 cu....
    Maytag MZD2766GES refrigerator quit cooling, both sides. Noticed frosting on freezer contents, and next day the ice maker ice was melting and running on the floor. We can hear a clicking every 5-10 minutes...
    How to check stuff>
    http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
    . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
    Is the compressor motor running.If no check starter/overload relay. Remove the cardboard backing from the back bottom to access the compressor area.
    Dec 20, 2009 | Maytag MZD2766GES Side by Side...
    My freezer's defrost systems runs constantly
    i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
    Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
    Refrigerators Logo
    52 people viewed this question
    Top Amana Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Sal De
    Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
