Question about Dell Latitude CPI-D Notebook
Just tried to install xubuntu using cdrom to dell cpid266xt. Installation was going fine (55% copying files) so i left it for about 10 mins. Came back - dell switched off (assumed battery flat). Put power back, tried to reinstall - no luck - when hdd accessed dell powers of straight away ! Tried disk check - same thing. Memory test worked ok tho - no disk access to check memory. Is there a secret partition on the disk that the xubuntu install overwrote - so now laptop cannot see partition and powers off. Any method i could use to recreate secret partition ?
  • myfatspambuc Jun 27, 2009
    Yes - I think you're correct. I put the power back on (battery at 6%) and it still wouldn't work (disc access failed). But i left it on charge and tried another distro when the batt was at about 60% & hey presto it's now installing... !
    I suppose the hdd won't work if the batt is low even when on mains power - phew - thought i'd bricked the system for a while ... thx
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    I have a dell 1501 laptop i was experimenting with putting xubuntu on it and I only had the ac adapter on it. I was worried that If i only had battery power on it that it would turn off on me. Try it with only the ac adapter on it and that should allow it to got thru. It did on mine, only thing at that point is that you will need to configure the system and to hopefully get the right drivers.
  • Dell Master
  • 2,404 Answers
Glad the ac adapter only being hooked up worked. Keep in mind that when batteries get to low that they can actually short out a laptop. Just some good info to know for the future. Hey if you can rate me on my solution to you I would be much obliged and I hope you get ubuntu working properly. I still want to get it to work on my other laptop, seems like a cool operating system.
Posted on Jun 27, 2009
I have a dell 8200 and want to take that info to the dell e520 hard drive is there a way to piggy back the two hard drives together so i can tranfer files to the e520 or can I at least copy some file
Hi ,
yes you can open your case and there should be two ide cables , one to your harddrive the 2nd to your cdrom/dvd player , diconnect the cdrom drive and use the cable to go into your 2nd harddrive , copy all you want , then just reinstall the cd drive and your good to go ............you might have to go into your setup or cmos and have the harddrive detected ......................Good luck Roy
Nov 09, 2011 | Dell Dimension E520 PC Desktop
Tip
HOW TO REINSTALL WINDOWS XP OR INSTALLING CLEAN COPY
How to reinstall Windows XP operating system or installing fresh copy of Windows XP on your computer.
If your Windows XP operating system had problem due to corrupted files, viruses problem or you want to upgrade your system. This procedure will guide you in reinstalling your current Windows XP or installing fresh copy.
After this installing process, you need all your hardware drivers like Chipset Intel driver, LAN driver, Sound driver, WAN driver, Webcam driver and others for the computer to be fully operational. Otherwise, do not proceed on reinstalling you operating system if your do not have those hardware drivers.
CDROM drive is required for installing Windows XP. If you don't have in your notebook computer, use external CDROM drive to connect in your computer using a USB cable.
1. To start with, you need to back up your in blank CD all your important files before you begin installation produre because all the data will be wipe out.
2. When ready, start your computer and when booting press F2 to
BIOS setting.
3. On BIOS menu, choose the BOOT setting and change the priority boot to CDROM, exit and save.
In some laptops, you can skip this BIOS setting process by repeatedly pressing F9 key or F10key when booting your computer and it will run boot priority on CD.
4. Once you exit from BIOS, you computer will reboot and a message will appear " Press any key to boot from CD", press any key to enter into WINDOWS XP SET UP.
5. Belows instruction messages will appear:
* To set up Windows XP now, press ENTER
* To repair Windows XP installation using recovery console, press R
* To quit set up without installing Windows XP, press F3
Press ENTER to initiate the installation.
6. You will go to Windows XP license agreement and press F8 to agree.
7. You will ask you if you want to REPAIR or REINSTALL the operating system. It will appear like this. Just press ESC to proceed.
A. To repair the selected Windows XP installation, press R.
B. To continue installing fresh copy of Windows XP without repairing, press ESC.
From repairing your operating system, it will not removed all your files and other software installed in your computer including your hardware drivers installed. Just fixing the operating system.
For reinstalling the operating system, you need to back up all you files because it will wipe out all you datas in your computer.
8. After that, it ask you where partition you want to install the operating system. The message will display like this :
C : Partition1 [NTFS]
D : Partition2 [NTFS]
Unpartitioned Space
Use the directional key to navigate and choose C: Partition1 if you want reinstalling Windows XP and press enter.
If you want clean copy of Windows XP, you need to delete both partition by pressing L and install clean copy at Unpartitioned space. By these procedure, you will have C: drive only. D: Drive is delete.
9. After choosing the desire partition. this will appear :
* Format the partition using NTFS files system
* Format the partition using the NFTS file
I suggest to choose the first line which is the quick format. The 2nd line take too much time to install the operating system. Press to initiate the installation and it will be finish and reboot automatically. PART OF WINDOWS INSTALLATION IS FINISHED.
If you had interrupted installation which is asking for certain driver file, your CD installer maybe damage which cause files to be unreadable. Try to replace the new Windows XP installer CD to proceed and until finished installing OS.
10. Once it reboots, this time do not boot from CD or do not press any key to go to PART2 OF WINDOWS XP INSTALLATION PROCESS.
11. On the opening, regional and laguage option will appear, jus click next.
12. The it will ask to type your name & organization. Put you name and company if any and click next
13. Then, it will ask for CD key and type the 25 character CD key and click next
14. Then it will ask for computer name. You can change or leave it and click next.
15. Then, set your date and time zone and click next.
16. Then, it will ask you for workgroup and computer domain, just leave it and click next.
17. Now wait until the installation process end and it will again restart automatically.
18. Again, do not boot from CD and display setting will appear. Just click OK.
19. welcom to Microsoft Windows screen will appear. Just click next.
20. Helps protect your PC will appear and choose Turn on Automatic Updates ( Only if you install genuine Windows XP). Otherwise, I suggest to choose "Not right not" if you are installing copy only of Windows XP.
21. Who will use this computer message will appear. Just type your name on the first box and click next.
Also for your reference, here is the video for your convenient .
A thank you message will appear, Just click next and it is finished.
I hope it helps you and thank you for using FixYa !
For repairing the operating system here is the blog as other want it.
As per others demand, here is the video for Windows 7 and Windows Vista Operating system
on Dec 23, 2010 | Computers & Internet
My System is affected by virus.when i format the total hard drive still it can run within some days.how 2 remove this virus manually or help 2 format the drive using any bootable software...plz...
I suggest booting from a bootable cdrom disk, instead of a floppy disk, USB drive, etc. Everything except the cdrom can quite easily become infected with a virus just by plugging it into the computer. You MUST create the bootable cdrom from a KNOWN clean computer! If you try to create one from the infected system, you can almost be assured you will only create an infected cdrom!
If you don't have a way of creating a bootable cdrom, try booting your system from your Windows installation cd / dvd. Do a complete format before the install and then SHUT DOWN the computer! Do NOT just reboot and continue with the installation of the OS. Viruses are "memory resident" in that they load themselves up into RAM when the computer boots and will remain there until the machine does a complete shut down. I recommend you shutdown (i.e., turn off the computer) and restart the machine a couple of times AFTER doing the format to be assured that the virus is eradicated.
Once you are satisfied the virus no longer exists, you can go ahead with a new install of the OS. The FIRST thing to do before loading ANY of your personal files back onto the computer is to install a virus scanning software -- and make sure it is active and the virus pattern files are current. After scanning the hard drive for problems and finding none, can you go ahead with the installation / restore of your personal files.
Chances are pretty good that the reason the computer runs OK for a couple of days and then the virus reappears is that a file you have installed or copied over from your backup is infected. Each time you launch the program / file, the virus gets installed and the cycle starts again.
Jan 23, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Sata hdd windows dell recovery cd will partition install windows
The system is originally designed to use IDE HDD, make sure the necessary chages for Sata HDD are made in the BIOS, next make sure the Recovery disc is fine without any scratches. You can order a new Windows OEM recovery disc by calling Dell tech support (1-800-624-9896-US) and try installing the OS. The disc will cost you not more than $12.
Nov 15, 2009 | Dell Dimension 4700 PC Desktop
DELL DIMENSION REFORMAT WITH DISC
probably ur ram is faulty..replace with a standby n see..
also check for defective capacitors on the main/mother board..
reinstall os..
..contact ur system admin/vendor
Oct 27, 2009 | Dell OptiPlex GX150 SF PC Desktop
I have a dell inspiron 6000 it was working good at first but now when i turn it on it is telling me that windows could not staer because the followin file is missing or currupt: <Windows...
Do a windows repair, you can do this by using your windows xp disk, make sure that the first boot is set to your CDROM in the bios. restart your pc, you will see the windows installation screen, select to repair windows and follow the prompts. If you still need help I will be more then happy to walk you threw the whole process. Just let me know.
keiffertech@techie.com
Sep 07, 2009 | Dell Inspiron 6000 Notebook
Installing XP on a dell computer
try to go to bios and load bios defaults, esc then save and exit. boot from the cdrom by, tapping on F12 at dell screen. at boot menu screen, choose cdrom, press enter, when you see the message, PRESS ANY KEY T5O BOOT TO CDROM, hit any immediately, that should allow you to install xp directly from the cdrom.
Feb 13, 2008 | Dell Dimension 4600 PC Desktop
Installing xp
what i can suggest u is(1) boot from the cd first to do that at the starting of booting press del key in keyborad and u will go to cmos there u change the first boot priority to the cdrom then save and exit the setup put the xp cd in cdrom restart the computer and it will show like boot from cd windows xp... press enter it will boot and then follow the instructions or (2) else if u alredy have any operating system working on ur comp then go to the operating system and then put the xp cd the cd will auto run there it show u setup or install windows xp after that it will boot from there follow the instructions any of the comp can have windows xp might be u have got a non bootable disk then go to the(2)solution
Nov 20, 2007 | Microsoft Windows 98 for PC
Reading Data CD's
Hmmm... were the cd's originally burned using that laptop? Or were they burned on a different pc?
It could be as simple as your cdrom doesnt like something about those cd's. Or it could be a flakey cdrom.
My suggestion, try reburning them to a different brand of disk using a different pc. Then see if your laptop will read them. If not, may need to replace the cdrom. Though it reads commercially manufactured cd's, if its flakey, it will have problems reading custom made cd's.
Other option, get a usb flash drive and copy those files from that cd, in a different pc, to the flash drive.
You don't need any special drivers or programs in order to copy mp3 files from a cd to your hard drive. Yet, you would need something in order to play them. Which media player does just fine.
Flakey cdrom or flakey cd's... hope this helps.
Oct 29, 2007 | Dell Latitude D600 Notebook
Dell Latitude CPI-D Notebook Logo
171 people viewed this question
Alun Cox
