Question about GE Microwave Ovens
I just found a hole in the back corner of a microwave oven that I've been using for over 2 years without any problems. Can this be repaired?
  • GE Master
  • 9,098 Answers
The area will first have to be sanded smooth and cleaned and dried thoroughly.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Posted on Jun 28, 2009
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
I have an Electrolux High Speed Oven E30SO75FPS that's 3 years old and the Magnetron has failed for the 3rd time. What can be causing this?
Is the internal cooling fan working?
Are the ducts and vents clear?
Problems with any of those can result in overheating, which destroys magnetrons.
I have seen high voltage rectifier diodes interact with magnetron in funny ways. I'd replace the diode, too.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Finally, baking potatoes and making popcorn really give the magnetron a workout.
You should put about 1/2 cup of water in the rear corner of the microwave when cooking those foods.
It helps "preload" the oven to prevent execessive microwave energy reflection back to the magnetron.
We're
Dec 12, 2011 | Microwave Ovens
GE Model Spacemaker Microwave Model #JVM1650WB008 handle broken.
Appliance Repaired: General Electric Microwave
Model: g
Age Of Appliance: 5 - 10 years
took a screw driver and pride off plastic on inside of door. be carfule not to break it. only one of two screws that go into handle were visable. had to drill a hole in metal braket to get at second screw. you can just bend the metal braket back inorder to use drill. bend it back when done. took off handle and replaced it. snapped plastic piece I took off back in place and finished.
ge told me i needed to replace whole door. which they nolonger stock and I could not find a whole door for my model on web. found handlw on this website and did it my self
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R1505
We have affordable solutions for both problems.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
What happens all too often is that a shop will replace your board with a board which has (what in my professional opinion are) built-in weaknesses in design and manufacturing.
Our repairs include our proprietary upgrades designed to repair and prevent future display failures.
Or you can order a fully-upgraded control unit to avoid being without your microwave during the repair period.
Our repairs also include a new and improved select button assembly, or you can order one here and install it yourself.
Details are at our Web site, and we also have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 13, 2008 | Jenn-Air JMV8208A Microwave Oven
GE JVM1190WY 003 Microwave Convection sparks
The problem that you are having is that the magnetron inside the microwave is shorting out to ground and it will find the shortest path to reach whatever has metal in it. Replacing the magnetron will solve your problem altogether and you need not do anything else different and continue using your metal racks.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Microwave Buzzing When Not in Use
Are you using a 3 pronged outlet and is it grounded? If you have a 2 holed outlet and are using a ground eliminator adapter, try turning the plug around to reverse the polarity. If this helps, then it would be advisable to have an electrician to ground your oven.
May 22, 2008 | Whirlpool MH7140XF Microwave Oven
Panasonic Inverter NN-V673S microwave- shuts off after 2-30 secs
If the screen is showing a fault number or a number you havent seen before then its probably a program fault which can't be fixed. Check that the vent holes on the back of the oven aren't dirty and ensure that the whole oven is clean inside. Sadly it sounds like a program fault which cant usually be fixed by the owner though.
Finding a Panasonic oven repairer in the UK shouldnt be a problem though. My parents had a simlar problem wth their Panasonic Inverter oven, called the UK customer services and Panasonic contacted an authorised repairer in Scotland to visit them. Call customer services on 0844 844 3868.
If the call out charge exceeds £80 then you're probably better off buying a new oven.
Apr 19, 2008 | Microwave Ovens
Microwave oven blows breaker after 2-3 secs
make sure that your microwave is on its own circut breaker meaning nothing shares the plug
Mar 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
153 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
