Question about Sony Cyber-Shot DSC-W5 Digital Camera
Battery life only lasts for a dozen shots, i have tried new batteries but no diffrent, battery indicator starts full and after a few shots is done to halfway before dying completly, any idea's
  • 3 Answers
Hello, peterdearsam,
I had exactly same issue with mine and tried so many ways to fix this. Was even ready to buy some new camera instead of this Sony dsc w-17 but then found a way of resetting camera in such way: powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times. It helped
Posted on Aug 08, 2009
I have a new refurbished kodak easyshare c160 -- the camera will not last but for one or two pictures without completely draining the batteries. i have tried about 4 new sets of photo batteries....is this...
Solution: As digital cameras become more advanced and include more features, the power needed to keep them functioning has also increased. That means that typical alkaline batteries likely won’t do more than power your camera for a few shots before running out of juice. Sometimes, your digital camera may not power on at all if the inserted alkaline batteries aren’t fully charged or powerful enough. Rather than carry along dozens of alkaline batteries for a single photo shoot, you can save money by purchasing rechargeable NiMH (nickel-metal hydride) batteries. Rechargeable batteries can be purchased with a charger that you plug into a wall outlet, and they fully charge in one to five hours depending on the charger and the type of batteries you’re using.
If you’re already using rechargeable batteries but are experiencing short battery life with your digital camera, it’s likely time to replace your rechargeable batteries with new ones. Depending on the number of charging cycles you perform (how many times you discharge and recharge your batteries), rechargeable batteries typically last for two to three years before they no longer hold a full charge. You may also ensure that you’re charging your rechargeable batteries directly before use. As batteries sit unused for extended periods of time, they automatically lose some of their charge.
There are many ways you can conserve battery life while using your digital camera, too. For starters, if your camera has a viewfinder in addition to an LCD, use the viewfinder to frame your shots and turn the LCD off because LCDs draw a lot of power. If you prefer to use the LCD, you can still conserve battery life if you refrain from looking at each picture on the screen after you take it.
Jun 13, 2010 | Kodak EasyShare C160 Digital Camera
I am in Pune 411004 in India and have purchased Samsung digital es 15 camera recently. Original 2 aa Alkaline batteries have been completely used up.when I replaced these with 2 new eveready batteries...
Jun 13, 2010 | Cameras
The batteries on my Sony Cyber-shot 6.0 run out very quickly. This problem has just started in the last few months - before that they lasted well. Is this a problem that can be fixed?
HI there its a problem of your battery. Just replace the battery & enjoy the photography. The battery which is you using that finish his life. After charging it will show you full but its fastly drop down when you use. Thanks.
Apr 03, 2010 | Cameras
Camera starts to boot but suddenly shuts off.
Assuming the battery is fresh out of the charger: a "well used" battery that can no longer accept a full charge (at the end of its useful life) can have the results you describe (it's not unlike like a flashlight with dead batteries - when the light goes out, turn off the flashlight - wait a few minutes and turn it on again - the light shines [though not very brightly] and quickly goes out again). After many charge / discharge cycles, the battery no longer has the ability to hold a charge. This is a gradual process that happens over the life of the battery. An indication of this is that you'll notice that you can take many fewer shots now when compared to when the battery was new.
There is a possibility that a new, fully charged battery will allow the camera to work again. However, if the existing battery is not very old or or has relatively few charge / discharge cycles, it is probably an issue with the camera. A local camera store may be able to help you determine if it is a battery or camera issue - otherwise, a quick google search reveals that a new battery for this camera is under $15.
I hope this helps - and good luck!
Nov 13, 2009 | Kodak EasyShare C653 Digital Camera
Olympus x-840 digital camera. Hi, there is a problem with the battery life; fully charged batteries seem to be exhausted after only a dozen or so pictures. The battery indicator plunging from a full set...
The best solution is to buy NiMh batteries 2300 mA or greater 2500 mA to 2700 mA and so I have no more problems with this excellent Olympus x 840 camera. In Belgium i have payed a little more than 50 euro for the batteries and the charger.
Lionel From Belgium
Apr 14, 2008 | Cameras
Battery Life
Your SD memory expansion card may be damaged.
Try the same procedure without the expansion SD card.
Use the Casio QV-R40 10meg memory with same camera settings.
Dec 16, 2007 | Casio QV-R40 Digital Camera
Panasonic lumixDMC-FX7 camera
Could be either. If on switch on again the indicator is full and you get more work done then its a camera fault. If when you switch on again the battery remains flat then this could be the camera fault too the flash capacitor showing signs of distress. On the other hansd the battery could be nearing the end it useful life. How much is a new battery?
Aug 29, 2007 | Panasonic Lumix DMC-FX7 Digital Camera
P850 Battery Problem
clearly an issue with Kodak. sounds like they erred with the firmware.
Jun 04, 2007 | Kodak EasyShare P850 Digital Camera
Battery Problems Canon eos 10D
My battery works for weeks. It might be a problem with the camera. Could it be the contact points in the camera?
Nov 28, 2006 | Canon EOS-10D Digital Camera
Sony Cyber-Shot DSC-W5 Digital Camera Logo
340 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
