Question about Canon PowerShot A550 Digital Camera
When I turn the camera on it shows lens error and shuts off
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jun 28, 2009
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
Tip
Sanyo digital camera showing lens error 1114 or 112
Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
When I turn on the camera, Lens error shows up on
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Dec 27, 2009 | Nikon Coolpix S210 Digital Camera
The lens comes out then the camera turns off
Your camera has it own doctor built in, if it sees an internal error it will shut down. When a camera turns on it goes through a series of tests, if one of these test fails your camera records an error. If the lens is moving in and out your camera is trying to get the lens to function. As such you have a faulty camera.
Jul 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
Screen says LENS ERROR
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 18, 2009 | Pentax Optio E60 Digital Camera
My sanyo vpc-e760 digital camera is showing lens error:22 what do i do
well i have a SANYO camera and every time i cut it on it cuts on a little bit and i see it and it sais lens error: 308 what does that mean?
Oct 08, 2008 | Sanyo VPC-E760 Digital Camera
Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Aug 03, 2008 | Sanyo VPC-E760 Digital Camera
Camera problem, shows "Acsess"...
May 30, 2008 | Cameras
Camera Lens problem
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 28, 2008 | HP Photosmart M525 Digital Camera
Camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Mar 29, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Canon PowerShot A550 Digital Camera Logo
78 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
