It is leaking
The drain line located in the back of the freezer section has clogged. Some drain lines are located on the outside of unit. If drain line is outside of unit, disconnect line, use a shop vac and place it over the connector and suck out debris. Then blow out the drain line, then connect drain line. If drain line is not visible on the outside of unit and there is no visible drain inside of freezer,, remover all food from freezer, remove the back wall in freezer section. You should see a drain in the middle, back of the freezer, Use sop vac and remove debris. If you don't have a shop vac, you can use a long straw, wrap tape around end to make a tight fit and blow out the debris.
Good Morning Friend, I understand you want to know where the drain line is for your Frigidaire refrigerator. I will be more than happy to assist. So I am able to better assist, I kindly ask that you leave the model number of your refrigerator. Looking forward to hearing from you. -WP-
