Machine lcd, water fill, drain pump etc all operating correctly, but the drum will not turn for either the wash or spin.
  • 82 Answers
Moter or brushes have gone
Posted on Jun 28, 2009
Why won't Affinity fill or spin?
Probably there is water in the drum or the pressure switch is jam in a state of "full of water" or washing machine didn't drain water .. So, the fault should be sought in the elements responsible for control the level (pressure switch, pcb...etc.) or control draining water (drain pump, pcb, filter....etc.).
The precondition that the machine goes into a spin cycle is that pressure switch folded down to position "empty of water".
Dado
Jul 24, 2015 | Frigidaire ATF6000ES Front Load Washer
Need help
Are you saying it is draining the water properly? Because it sounds as though the pump is faulty. Every now and then you get pup motor that don't short out or stop completely they just don't drain we'll anymore. The drain period on your machine is timed so a slow drain may cause the error. So even though everything is clear and 'working' the pump needs replacing. Another cause would be a false reading from the pressure switch(level switch) but you would normally have problems with fill etc also, so unlikely.
Jul 09, 2013 | Washing Machines
My washing machine fills up but the drum is not spinning
Hi calex if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 18, 2013 | Beko Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
When I start any program on my Miele Novotronic W820, the machine fills with water and drum starts to turn but after a short time the main wash light flashes on and off. I've tried clearing the program,...
you may find that the water pump is not operating properly as the first fill of water is normally pumpt out first before the wash fill is started unplug the machine and take the back panel off and locate the water pump and check if you can move the cooling fan at the rear of the pump freely if not the take the water outlet pipe off and remove whatever is stopping the rotation of the pump replace all parts and run the machine to see if the fault has been found and cleared eric
Jan 05, 2018 | Washing Machines
Water pump failure?
The water pump drain motor has something stuck in it or it has gone bad like most LG parts.
Remove the drain pump and look for any foreign object to be removed.
Check the drain pump for a failed pump motor.
LG is pretty.
Feb 02, 2010 | LG WD-3274RHD Front Load Washer / Dryer
Washing machine will fill with water, but won't spin.
hi there.
If the washer won't drain or spin there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014
SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...
or go to this link for more help.
Washing machine will fill with water but won spin Google Search
Nov 18, 2017 | Whirlpool 3.2 cu. ft. Plus Washer
Washer not draining water
It is likely that something is stopping the pump from operating. Most machines allow access to the pump to remove coins etc which can stop the pump operating
Jul 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
