Its really a small turbine that sits in the the air flow so if its not turning its either stuck with hair etc wrapped around or it may have a small rubber belt the top or bottom of the tool will be easily opened maybe two or three screws then seperate into two halfs.seems like dyson must have allowed use of"cyclone"suction system on a vax,they sued hoover when they used it.
first, if it has a hose check for being plugged, you may have to take the vacuum apart further till you reach the fan on motor which may have hair,lint,etc wrapped around it which can cause low suction. Checking for Blockages in Your Vax Upright Vacuum Cleaner
press helpful button
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41018&thid=618510 Dusty smell Posted by chekle on May 23, 2008 I buy loads of Hoovers and always same problem. When I Hoover its a dusty smell and it stays around bag not full and check filter the Hoover is ok f couple days then this happens. Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5881-900 Vacuum. It sounds to me that if you have a clean bag and filter, it sounds like you have dust in the motor section and it needs to be cleaned and or take a good blower and blow out the dirt or you may have a clog or dirt build up in the suction line and that might be causing the dusty smell. Please feel free to contact your local vacuum cleaner dealer in your area or call the Hoover factory and ask for tech support. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. http://www.hoover.com Telephone Contact our Customer Service Department at 1.330.499.9499 Monday through Friday 8 a.m. - 7 p.m. EST Thanks, Don the Vac Man Go Ahead. Use Us.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553160 Generic problem for all Vacuums I have a Vax Rapide Posted by paulxlyn on Apr 28, 2008
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits do you think it can be repaired?
Hello, I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Yes, you can contact your local vacuum cleaner dealer and if they don’t carry the Vax Model then feel free to contact the Vax Rapide Factory Manufacturer phone number or the website for further information and to order parts if needed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. http://www.vaxusa.com/ If you have specific questions and you can't find the answer you’re looking for here, please call our Customer Service Department at 877.894.2031 M-F 8AM-7PM EST or check out our Contact Us page for more information. Thanks,Don – The Vac Man Go Ahead.Use Us.
i have one of these too and it used to keep cutting out, replaced the filters and now it wont even turn on. changed fuses everything, and now im stuck with a dirty house....
