Question about HP Computers & Internet
The wizard detects my usb modem but can't install its software from its installation cd
    Problem Solver:
  • 6 Answers
PENGE AMAN CHEAT SA SF PWEDE???
Posted on Jun 27, 2009
How to install anti virus
Insert the USB flash drive into one of the USB ports on your computer.
Momentarily a small prompt will appear saying the computer has detected a new removable device.
Insert the antivirus software installation CD into the disc drive of the computer to launch the installation wizard.
If you downloaded the program, double-click the downloaded file to launch the installation wizard.
Read through and accept the license agreement, then click "Browse" when shown the installation location.
A search window will appear on the screen. Choose the USB flash drive and click "OK."
Click "Next" for the installation name and select "Install." The antivirus program now will install onto the USB flash drive
hope this helps
Oct 10, 2012 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Brother hl-5280dw printer just stopped printing. pc says doc failed to print - printer error or busy. test pages work directly from printer but printer does not recognize that documents are being sent to...
hi try re installing the software of the printer .completely uninstall first the previous software of your printer then install it again.to begin with the installation do no connect first the printer usb cable run first the CD the follow the wizard instruction installation.wait till the wizard prompt you to connect the printer and power it on.in this process the computer will automatically search your printer.then click next.until installation is successful.
you can also replace your USB connector for your printer if the computer cannot detect your printer..
good luck!
Jul 08, 2011 | Brother HL-5280DW Laser Printer
I have tried in vain to get the USB connection on my Westell 6100 to work. Are there some tricks to making this happen? The ethernet connection will work fine, but I cannot get the USB setup to work at...
I suggest that you use ethernet connection instead of the USB connection.
Ethernet is more stable that USB, you less likely to experience dropped connections.
Also take note that you can only use one connection at a time. You CANNOT use Ethernet on one computer, then USB on the other computer.
But if you insist to use the USB connection, you need to install the drivers. Once the usb cable is connected to the modem and computer, you will get a found new hardware wizard screen. Then you will need to insert the CD that came with the adapter to your computer.
If the found new hardware wizard did not appear, check your device manager and look if there is a USB adapter with a question mark or exclamation point. Right click on the USB adapter then click reinstall.
It should detect the drivers from the cd.
Good luck and have a great day!
Jan 11, 2010 | Westell Wirespeed LiteLine 6100...
Whenever i am connecting the lg lxu-800 usb modem in my computer it is asking for the device driver software.Although i have the cd,still it is not getting detected.
  1. Disconnect modem from computer by taking out the usb lead from computer
  2. insert modem cd in cd/dvd drive and run install
  3. Install the driver from the cd
  4. follow directions onscreen the restart computer if necessary
  5. plug modem back into usb port
  6. now when windows detects it it will find the correct drivers
Welcome
Jun 22, 2009 | Computers & Internet
How to connect usb conection from my data one "UT-300R2U" modem to compaq laptop.we have usb cable and driver cd but drivers are not installed in my laptop.plz give me the complete solution for this...
If you are using Windows Xp, just connect the modem using USB/LAN it will be automatically detected & software for it will be installed. Then you can just set up a connection, put in your username & password, done.
If you are using Windows Vista / Windows 7, modem in LAN mode will be installed automatically like XP, but not in USB mode. Because there's no USB driver for UT300R2U (BSNL modem) in Vista. You need to find a ZTE Remote NDIS device driver, install it & then you can connect. Hope this will fix your problem.
May 12, 2009 | Computers & Internet
Run Installation Wizard..
Yes. This means to say that you need to install all software that came with the modem, contained in a disc before connecting (installing) USB cable or anything else. After installation of the software and computer is restarted you can now then connect all peripherals for modem connection.
Jan 02, 2009 | Westell Wirespeed LiteLine 6100...
Computer does not recognize my westell modem thru usb
yes.. you may do that and also, please make sure that the drivers of the USB ports on your computers are installed..
Dec 09, 2008 | Westell Wirespeed LiteLine 6100...
Cant get modem to run the cd to download my printer. it is a 7100 series. is it the CD?
If the disk is not working you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find thefile,double click on the file, then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista
Oct 15, 2008 | Lexmark Office Equipment & Supplies
Will my modem work if I run it thru u usb instead of ethernet cable?
IF your modem has a USB and ethernet connectivity , yes it will work you just need to install the software for your modem so you can use it via USB connection , the software should come with your modem just run that software and follow the setup wizard and that should be it....
Hope that helps............
Sep 30, 2008 | Computers & Internet
CAN NOT FIND SOFTWARE TO INSTALL HARDWARE
here, read this - you should use an ethernet cable to install the router - it is alot easier but here is the manual that will tell you exactly what to do - http://www.buffalo-technology.com/support/getfile/?WBMR-G54+Manual.pdf
Sep 19, 2007 | Buffalo Technology Buffalo AirStation...
Computers & Internet Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
