Question about Acer Aspire L100 PC Desktop
Gateway we have 3 pc's 2 are working on the internet one won't it wont renew ip address and says gateway is offline
    Guru:
  • 155 Answers
Try competely cancelling all internet connection on the pc that won't work then restart your computer and set it up again from the start.
Posted on Nov 06, 2007
I have an acer aspire and it won't connect to our
First check the ip address:
1.Go to the dos prompt and type in ipconfig
2. An invalid ip address is anything that start off with 169.xx.xx.xx
3. If it give you an a valid ip address, go to a blank line on the dos prompt
4. Type ipconfig/release..press enter. A lot of information is going to come up
5. Go the next blank line in dos type ipconfig/renew.
6. Then power cycle the modem and computer by turn the modem completely off and then turn off the computer for 3 minutes. Then turn the modem and computer back on. Check to see if this work.
Jun 05, 2011 | Acer Computers & Internet
Every time I run the DSL-504 ADSL2 Ethernet Router CD disc to setup my internet connection, always get the dslultility.exe message say "modam not deteched....." but everything is...
To release and renew IP address, go to Start > Run. Type in CMD and press Enter. At the prompt, type in ipconfig and press Enter. This will display the adapter information such as IP address, Subnet mask, and default gateway.
To view additional information such as Mac address, DNS servers, etc, type in ipconfig /all.
To release IP address, type ipconfig /release.
To renew IP address, type ipconfig /renew.
If you are not able to get an IP address try setting one statically:
Windows 2000
Step 1 Right-click on My Network Places and select Properties.
Step 2 Right-click on the Local Area Connection which represents your network card and select Properties.
Step 3 Highlight Internet Protocol (TCP/IP) and click Properties. Enter your IP information for your network.
If connecting to a router, make sure the default gateway and a DNS server is the IP address of the router (192.168.0.1).
Windows XP
Step 4 Click on Start > Control Panel > Network and Internet Connections > Network connections.
Step 5 See Step 2 for Windows 2000 and continue from there.
Nov 06, 2010 | D-Link Computers & Internet
I am trying to hook up a Samsung WIS09ABGN LinkStick Wireless USB 2.0 Adapter to a Samsung BD-C5500 Blu-ray DVD player. In going through the setup process after I set up the router connection which...
To resolve issues with the Internet Gateway connecting to the MyQ server
1. Determine if you can connect to the Internet using your computer. If you cannot connect, proceed to step 2.
2. Reset the router. Unplug the router for 30 seconds and plug back in. It can take a few minutes to reconnect to the internet. If you still cannot connect to the internet, contact your Internet Service Provider before proceeding.
3. Move the Internet Gateway ethernet cable to another port on the router. Put it in one of the ports on either side of the current position on router. Make sure that the Internet Gateway is plugged into a LAN port, normally numbered 1-4. Proceed to step 4 if none of the ports work.
4. If you are using a modem and a router, disconnect from the router and plug the Internet Gateway directly into a LAN port in the modem to bypass the router. Note: This will turn off the internet to the rest of your home network temporarily. If this works:
5. If step 4 doesn't work, power cycle your home's internet modem, it may need to be restarted to provide a new IP address to your network.
6. Perform a Soft Reset on the Internet Gateway. This renews the IP address with the router. The LED lights will blink like a normal power up. To perform a soft reset:
1. With a safety pin or paper clip, press and hold reset button while the Internet Gateway is still plugged in.
Note: The reset button is located on the side of the Internet Gateway in a recessed hole.
2. Hold the button in until you see a yellow LED light blink and release.7. Perform a hard reset on the gateway. This deletes all the devices and renews the IP address with the router.
1. Unplug the AC adapter from the gateway.
2. With a safety pin or paper clip, press and hold the reset button on the side of the gateway.
3. Plug the AC adapter back in while continuing to hold down the reset button until the yellow LED light blinks.
Dec 08, 2017 | Samsung WIS09ABGN (8808993304486)...
Laptop won't connect to wireless internet
wat is the Ip address
default gateway
????? Fast reply needed for a quicker resolution
Mar 18, 2010 | Google Chrome
I have cable internet through Time Warner and their modem connects directly to my Dell Dimension 8200 PC. I cannot connect to the internet and I am told it is because my computer will not read the ip...
you need to flush your dns
unplug modem (min of 10 sec)
turn off pc
restart in this order
modem (wait until most of the lights are solid) then pc
if your still having trouble
--------------------------XP Only -----------------------------------------------------------------
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
---------------------------------Vista or higher----------------------------------------------
1) Go to Start and click Run.
2) Run window will appear. Type cmd and click OK.
3) Command prompt
window will appear. Type ipconfig. You then will see the IP address and other network information of your network card
4) Type ipconfig /release to release the IP address.
5) Finally type ipconfig /renew to get new IP address.
then if this dont wont restart the computer.
if its still not working you will need a local tech to see if the ip address is hardcoded into the NIC
Jan 06, 2010 | Dell Dimension 8200 PC Desktop
First of all sorry for my english i have 10 user pc and 1 server (windows 2000 sp4) and 1 modem i have static ip address in my modem and i give the local ip in my modem 192.168.0.2.......ok i give the...
Each of the eleven(!) computers needs:
1. a _unique_ IP-address
2. the IP-address of the "gateway" device
3. the "network-mask" (usually 255.255.255.0)
The IP-address for your server must *NOT* match the IP-address of any of the 10 computers.
The IP-address for your server must *NOT* match the IP-address of the "gateway" computerl.
Nov 13, 2009 | Microsoft Windows 2000 Server
IP address conflicting
Have you checked to see if either computer has a static IP address? that might conflict with the DHCP table.
Jun 27, 2009 | Belkin (F5D7230-4) Router (587009)
What's an IP address?
internet provider address. ring your provider and they will sort it
May 24, 2009 | Acer Aspire One PC Notebook
Need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically
Oct 28, 2008 | Gateway Computers & Internet
UVERSE 2WIRE 802.1 LAPTOP ADAPTER
Try to acquire an address from the router by performing a ipconfig /release command, then ipconfig /renew at the command line. If that doesn't work then you may have to manually enter IP address and DNS address and Default Gateway address in the IP Properties page of your adapter. Could be your present address is using APIPA or Windoze Automatic Private IP Address of 169.254.x.x
Jun 24, 2008 | Computers & Internet
Acer Aspire L100 PC Desktop Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
