Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
I have a DSR 250 Video camera and there are dirty marks showing up on the monitor which appear to be coming fom the lense. I have cleaned the outside of the glass but they are still there possible from inside lense. How can I clean the inside?
  • David Williams
    David Williams Jun 23, 2014
    It is a Sony DSR 250 DVCAM
    New Friend:
  • 13 Answers
SOURCE:
Error code 80 + lock up functions
Still, when this error comes back, you should contact Canon.
On of the options hinting, you should use Canon lenses. So perhaps one of the contacts is a bit dirty?
Try cleaning all contacts in your camera, involved with lens and battery connection. Sometimes changing a lens can have a cleaning effect to. Most of the time not forever.
Success
Jan 20, 2014 | Canon EOS 5D Mark II Digital Camera
While recording video i get error message cleaning tape with x mark on it
Try using a head cleaning tape recommended by Sony.
If after two or three passes it does not improve, you should take the camera to a Service Centre for a clean and adjust.
Feb 16, 2011 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Where can i get USB driver for DSR-250
I think the drivers for your camera as my own are no longer supported in Vista or Win 7, but if you grab yourself a Fire-Wire cable you wont need driver okay? Magic I know but it works.
Jun 20, 2010 | Sony Dvcam DSR-250 Camcorder
Where can I find the mic that comes with the sony 250 and how much does it cost just for the mic?
The mic that came with the camera was very poor. Try a Sennheiser K6/ME64 (not ME66).
Nov 20, 2009 | Sony Dvcam DSR-250 Camcorder
Hello I have a canon IXUS 960 IS. Yesterday when I was using the camera it only closed half way when powering the camera off. Now the camera doesn't open fully and when pusing the "play" button the power...
If the outside of the lense get dirty, those small particles may prevent the lense from opening and closing 100% as nomal times. I had the same problem with my Sony. Here is what I did.
1- I cleaned the outside(sides not the lense itself) of the lense.
2- While turning the camera off, I press on the lense (up and down motion) NOT too hard for a few times untill it either retracted all the way inn or most of the way in. If most of the way in, press the lense a little harder untill it retracts 100%. If you turn it back on, it should work as normal unless some mechanical part of the lense is broken or dislocated. When it fully opens, clean up the outside of the lense and keep it always clean for normal operation.
Good Luck!!!!!!!!
Jun 11, 2009 | Canon IXUS 960 IS Digital Camera
MX1063 will turn on and lens comes out, but immediately turns off and lens goes back in. I charged it for hours and still nothing.
The outside of the lense may be dirty. When it comes out clean it. Or something else prevents it from fully opening. If it is clean, you might have droped it and damaged or broke mechanical part(s) of your lense. When it opens, try to hold the lense open, do not force it. If the did not help, take out the lense from the camera and inspect the lense. look for broken, or bent parts. Clean it and push the lense in and out. If it moves in and out without any problem, put it back on your camera. If the problem was from the lense, your camera should be back to normal.
Good luck!!!!!!!
Jun 10, 2009 | Kodak EASYSHARE M1063 Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
50 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
