Question about Sony PS-LX250H Turntable
My Sony PS-LX250H is all of the sudden playing too slow with a 33
Listening to some old school LP's and all is well. All of the sudden Johnny Cash sounds like someone is holding him back. Now none of my 33's play at normal speed. Any one know what's up? (FYI I know what a 45 is and no I didn't touch anything)
    Problem Solver:
  • 5 Answers
Not sure what made it happen all of a sudden, but you might want to check out Mocamom1 's question related to PS-LX250H speed & the attached solutions. You may just need to adjust the SW screw on the underside of the unit (worked for mine that was playing everything at 35 1/4!)
Posted on Jul 11, 2009
How do I adjust the speed of a Sony LX250H turntable? The answer is not in my manual.
Presumably you mean correcting the speed to play 45 and 33 correctly?
Some turntables have the speed control(s) as a preset(s) built into the base on the underside of the unit. Often covered with a sticker. You simply remove the sticker and stick a small screwdriver in the thing and turn it.
Others have the preset inside on a circuit board, got to by removing the bottom of the turntable. Others have it built into the motor itself.
You should replace the belt first if the speed is slow on both 45 and 33, before adjusting the motor speed.
Apr 25, 2014 | Sony PS-LX250H Turntable
Plays too fast
Either the speed switch is history or there is a belt problem. Get rid of it.
Jul 27, 2017 | Sony PS-LX250H Turntable
My Sony PS-LX250H Turntable suddenly started playing records too fast for both 33 and 45 speeds. Any ideas on how to fix???
If this is a belt drive then most of these speed increases are caused by the belt being in the wrong position. The belt could be faulty and my need to be replaced. Otherwise it could be due to a power supply problem, such as a faulty regulator to the supply of the motor. A check on the voltage to the motor will determine this. Assuming you know what the correct voltage should be! Of course with luck it will be higher than the motor is supposed to run at.
Feb 02, 2011 | Sony PS-LX250H Turntable
My audio technica turntable is playing records too fast. how do i fix this?
there are two small holes under the unit labeled 33 and 45 that control speed. im guessing youre mainly playing lps so use a flathead jewlers screw to adjust the 33 setting until you get the right speed
Jan 08, 2011 | Sony PS-LX250H Turntable
My Sony PS-LX250H turntable will only spin at 45rpm. When i push the speed button for 33 it doesn't change. i also sometimes have to give the deck a little push to get it to spin.
I have the exact same problem for the same model. Only spins at 45 and I sometimes have to kick-start it. I tried de-activating the switch (so that it's not making a connection) and therefore in the 33 position but that does not help.
Dec 14, 2010 | Sony PS-LX250H Turntable
Records turning at approximately 33 not 33 1/3. A
If it's not the belt some have speed preset controls which sometimes are found underneath (perhaps covered up) or they are on a pc board inside (accessed by underneathed).
Jul 31, 2010 | Sony PS-LX250H Turntable
Sony PS-LX250H is running slow from time to time notibly when playing slower songs like John Denver 33 albums.
Replace belt of turntable to fix speed issue. Part number is as follows:
421549201... BELT
Available in Sony Part Store for $10.31
Download user manual copy from Sony Support as belt replacement procedure is written in manual.
Thanks.
May 17, 2010 | Sony PS-LX250 Turntable
Turntable spins to fast
The motors are a common problem with this
model! Replace it to correct but I suspect the
motor regulator ic which is not avalible is the
real problem!
Apr 02, 2010 | Sony PS-LX250H Turntable
Sony PS-LX250H speed problem
I have a different Sony model (PS-LX-150H) that had a similar problem. I hadn't used it in awhile, and then when I did, I noticed the speed problem.
IF your PS-LX250 is like my PS-LX150, there are small speed adjustment screws accessible from the bottom of the unit. On mine, the two adjustment screws were labeled - one for 33rpm, the other for 45 rpm. Basically I just fiddled a bit with them using a very small precision screw driver until I could verify that I had reached 33 rpm (I used a stopwatch and literally counted the number of rotations/minute after making adjustments.)
Now it sounds right!
Mar 09, 2008 | Sony PS-LX250 Turntable
Sony PS-LX250H turntable won't turn
check the switch that make the lp running located it on the arm (arm uses to put it on the LP) check the motor Make sure no debris whatsoever that can disrupt the LP to turn
Aug 06, 2007 | Sony PS-LX250H Turntable
Sony PS-LX250H Turntable Logo
1,011 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
