Question about Planet Audio PX4000D Class D Monoblock Power Amplifier
My planet audio px4000d amp powers on but green or red light dont come on
I was bumping my system and out of nowhere it went off, i noticed that my battery fuse was bent so i replaced it and now the amp just powers on but neither of the red or green lights go on
    New Friend:
  • 31 Answers
Disassemble check internal fuse or for burned track also recheck the antenna connection -the thing that powers the amp on.Use a multimeter to test different points to ground potential. the one that doesnt have it has the problem.
Posted on Jun 23, 2014
SOURCE:
Planet Audio PX1500M Amplifier Problem
Check the FUSE to ensure that current is not cut off.
Jul 16, 2013 | Planet Audio PX1500M - 1500W MOSFET...
Kenwood amp red light
Red triangle is kenwood power light. Check rcas
Sep 24, 2017 | Car Audio & Video
I have an 06 kicker zx 1500 monoblock amplifier. The other day i was bumping it pretty hard and it just stopped playing so i stopped and then i stopped to look at the amp and the light was off but the...
Check the impedance of the speaker to be sure that it matches the output of the amp. Common error on this detail can cause the amp to overheat and shutdown/protect.
Jul 23, 2011 | Kicker ZX1500.1 Car Audio Amplifier
Red protection light
make sure amp is not grounded out or shorted out like if u miss and touch ground to power or the other way around protect light usaully comes on be resets once u turn the amp power off then back on . if that don't fix it maybe ur amp needs some repairs inside.
Jun 06, 2010 | Planet Audio VX4002 Car Audio Amplifier
What does the red and green light mean ???
red and green light? there is most likely a protection and a power light. The red I assume would either be a protection light or a clipping light signal. Does the amp kick off then these lights kick on red then to green?
May 31, 2010 | Planet Audio VX4002 Car Audio Amplifier
My subs don't bump to the beat, they just go THUMP THUMP THUMP...
It sounds like you need to ask for pro help mate, mybe the amp just needs setting properly, Is the amp on bypass for bass, or does the amp run the complete system
Jun 13, 2009 | Cadence TXA 750D High Power Mono Amplifier...
Both green and red ligt or on my jensen ka3 i dont know what it means i had it working b4 i swaped my subs for some new ones and the amp dosent work now.i dont know if is because of the red light but i...
Generally, the power light is green and the protect light is red. If the protect light is on there could be a short in the wiring or there could be an internal fault in the amp.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Dec 28, 2007 | Jensen KA3 Car Audio Amplifier
Battery light goes red after bumping/backing up
try this: turn it upside down and run it-then bump it to reverse it...same result?
May 29, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Planet Audio PX4000D Class D Monoblock Power Amplifier Logo
93 people viewed this question
Top Planet Audio Televison & Video Experts
Ekse
Are you a Planet Audio Televison and Video Expert? Answer questions, earn points and help others
