Question about Samsung HCL4715W 47" Rear Projection Television
Samsung Rear Projection 47" TV goes into stand by on start up
Make: Samsung
Model: SP47W3HFX
Was watching one evening whenjust cut off into stand-by, now every time I turn it on, it cuts straight of back into stand-by. Can somebody please help.
Thanks In Advance
Lee
  • 1,056 Answers
I am sorry to disappoint you but a TV problem can only be fixed by electronic technician. If you want to do it yourself, you would have to learn electronics. Start by learning basic electronic, and then read a book on how to fix televisions. Without knowledge in electronics, you won't be able to understand a book on fixing a TV. I have been fixing TV since 1998, and I started after dropping out of electronic engineering class. I learned most about electronics on my own, and you can too.
Posted on Jun 27, 2009
I have samsung hcn473 tv. The screeen is covered with squiggly vertical lines. Even watching a dvd movie, its the same.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or look like 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board is dead,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | Samsung HCN473W 47" Rear Projection...
Picture Moved Up
Check the cable and connections between the TV and your cable line. Make sure the contacts are clean, no bent pins, etc. Try replacing the cable if possible.
Jun 01, 2008 | Samsung HCL4715W 47" Rear Projection...
Samsung dlp hln617w does not tun on
this model number do not use lamp ?????????
Jun 09, 2010 | Samsung HCL4715W 47" Rear Projection...
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
My samsung SP47W3HFX just goes off and comes on again alone
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 01, 2017 | Samsung HLN5065W 50" Rear Projection...
Wavy red lines ,double vision
This is a convergence problem and if you can solder, you should be able to fix this yourself. First open up the back and locate the convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. Post the markings here and I'll confirm you have the correct ones. Try resoldering the pins on the ICs. If that fails to resolve the problem, you will need to replace them.
Keep me posted,
Dan
Nov 13, 2008 | Samsung HCM4215W 42" Rear Projection...
HCL47154 47IN REAR PROJECTION TV
sound like one of your tubes went dead..
Sep 30, 2008 | Samsung HCL4715W 47" Rear Projection...
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
392 people viewed this question
Jerry Greenberg
Jerry Greenberg
