Question about Sony Televison & Video
My sony tv falldown from the table color problem (rainbow pattern) developed but picture is ok. how to solve the problem?
    Problem Solver:
  • 17 Answers
It knocked the inside color wheel or tubes out of alignment. Check menus for "convergence" and try to readjust. You may need to call in a pro to fix it, but search your model number on trhe net and see if you can find the service manual.
Posted on Jun 27, 2009
I have a 8 year old 57in Sony projection HDTV,when the picture is dark you can see faint blue lines in a curved arch like pattern across the screen.Any ideas? Thanks
The tv problems is call a convergence picture problems,it is just starting to developing.This problems when it is fully developing into a convergence picture problems to the tv eventually.Tv will develope into a colors lines R,G,B mis alignments,have a colors shadow pictures or into a picture 3D look alike.Eventually the tv convergence board will dies,have to have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.This problems the tvs shops will cost u like $300-350 for parts and lobors.
Aug 13, 2011 | Sony KP-57WS500 57" Rear Projection...
Bullseye rainbow of colors
This is either a purity fault which is caused by magnetism affecting the screen. You would need to call a service engineer to remedy this as a special tool is required called a de-gauss coil. However there is also the posssibility that it could also be a fault with the shadowmask which is caused by the CRT itself, if this is the case then the CRT will need replaced & this would probably not be economical.
Nov 11, 2009 | Samsung TX-P3075WH 30" TV
I have a rainbow of color about the screen. The TV fell out of the stand and now the color pattern is messed up. It fell face down.
sounds like a degaussing (magnetizing) problem.could be that the posistor inside the TV set got loose when the tv fell down. If you have experience soldering electronic components, you should be able to fix it by re-soldering. Otherwise, call a tv tech to do it.
Jul 15, 2009 | Sony KV-27V42 27" TV
Sony KP-46WT500 Red, green and blue lines appearing on screen
your convergence IC;s are out, they cost about $40, if you know how to solder, you can do it your self, if not , I would try to find somone that can, service centers charge about 4 or 5 hundred, after you get the new ones, there easy to find on the board in the back of the tv
Nov 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Dropped Magnavox TV
Most likely the LCD panel itself had damaged.
Jan 01, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Sony Trinitron Color Rainbow
Usually when a tv is dropped the phospher screen inside the picture tube will detatch making the rainbow color This cannot be fixed as it requires changing the picture tube. Only other thing is demagnatize it with a demagnitizing coil (used by tv techs) but not likely to fix it since it was dropped. You have a bad picture tube.
Dec 30, 2007 | Sony KV-32FS13 TV
Dropped Magnavox TV
The shadow mask in the picture tube has shifted from being dropped. The only way to fix the set is to replace the picture tube, which would cost more than buying a new set.
Sep 06, 2007 | Televison & Video
Rainbow picture
The tube needs to be degausse you had maybe placed speakers beside the tv causing it to magnetize have a tech look at it to remedy the problem.good luck.
Apr 08, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
