Question about Microsoft Windows XP Professional for PC
My computers plug& play software is uninstalled
I cant find my dvd drive because my plug & play software is uninstalled
  • Tharinda
    Tharinda May 11, 2010
    How was it uninstalled?
  • 428 Answers
Did u check the device manager? From there check whether its disabled.
There are several possibilities for the failure;
1)Port disabled
Correction:Verify port is working by using Device Manager
2)Drive not powered on
Correction:Check power going to drive.
3)From a virus infection.
If u can, do a system restore (not sure whether it will undo it) or a system upgrade.
From device manager, go to event viewer. Check the system category for available errors.
Recently we have a fix for ya. Microsoft has released a fix. Go here and download. Make sure to be more careful with dvd players and burners, especially Roxio and Nero 7. And also from Viruses.
Hope tis would help you.
If it helps you please kindly rate this answer.
Thanks.
Posted on Jun 27, 2009
  • Tharinda
    Tharinda Jun 27, 2009
    1)Port disabled
    Thanks.
Power dvd 9 cant play dvd disc
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Sep 29, 2011 | CyberLink SW- DVD Software Power DVD...
Vrd-vc10 This burner does not recognize cd's Using Roxio software, after transcoding it will not burn to disc. It will not play a cd but will play a data dvd
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jun 22, 2011 | Sony Computers & Internet
Dvd drive will play music cd won't install software or read movie dvd's
there are two lasers in a dvd drive one for playing cd's and one for playing dvd's your dvd laser has failed. Hence why you cant play dvd's
Apr 08, 2011 | Toshiba X205-SLI2 SATELLITE X205-SLI2...
My Sony CRX320EE-88 cant read bootable cd/dvd. Yes it registers at the bios on boot up and its also detected on my windows start up but when it comes to playing cd's and dvd's, it cant read both of them....
make sure that the cdrw/dvd rom is getting enough power test all leads that are attached to the cd/dvd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 04, 2011 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
I removed my old cd rom that came with the computer and put the new one in.when i put the cd in that came with the new cd rom it said installation was unsuccessful.i bought the hp dvd1270i
Usually the software that comes with a new dvd/cd burner is just burning software (nero or roxio).
Your drive is just plug and play and windows has all the drivers that is needed.
I would uninstall the software you installed and try it with free software like IMGburn or CDburnerXP
Nov 07, 2010 | HP DVD±RW Burner
CD drive not recognized error code 0F00.281A
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program
Click Start, click My Computer, and then see whether the drive is listed.
Is the drive listed? loadTOCNode(2, 'moreinformation');
If the drive is listed, try to play or access a CD or DVD.
If you can play or access a CD or DVD, you are finished with this article.
If you cannot play or access a CD or DVD, you may have to reinstall some programs. Some programs might not be able to use your CD or DVD drive until you reinstall those programs. If the problem occurs again when you install or uninstall those programs, contact the manufacturer of the program to see if an update is available that solves the problem. Some examples of programs that might be affected are:
  • iTunes software by Apple
  • Nero software by Nero Inc
  • Roxio Creator software by Sonic Solutions
  • Zune software by Microsoft
After reinstalling your programs, if you can play or access a CD or DVD, you are finished with this article.
If you still cannot play or access a CD or DVD,
If the drive is not listed, remove and reinstall the existing drivers.
Nov 12, 2009 | Dell Precision T3400 375W 32bit Computer...
I cant play any movies..the dvd drive does not show up on my computer. what do i do ?
put same video codec for your computer, or a power DVD software.
Aug 11, 2009 | Computers & Internet
Cannot play dvds
hello have u recently removed any software. you might have by mistake uninstalled the dvd progam .
try this when you insert the dvd go to my coumpter then your dvd drive and then explore the contents of the drive to see if it reading it ok
if it is reading it ok i would say is is a software problem
hope this helps bob
Mar 25, 2009 | Toshiba Satellite Pro A210-EZ2203X...
Can't play dvds
What type of dvd are you trying to play? Is it an international dvd?
There are some dvds needing a different software to play. Let me know, and maybe i can help.
Nov 14, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Microsoft Windows XP Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
