Question about Air Tools & Compressors
Air compressor motor centrifical starter burned out. want to see what it looks like and where to get it in Arizon (kingman)
  • fredericksim May 11, 2010
    Need to know manufacture of motor to help you.
    disconnect power and take the back plate off the motor off and there it is . depends on manufacture
    Problem Solver:
  • 14 Answers
Try putting part or model # in google search
Posted on Aug 02, 2009
How do I wire my puma 220v sigle phase air compressor with s-p40t motor starter?
You contactor /motor starter has connection for up to three phase /L1 thru L3. You will be only using L1 and L2 connectors for power-in/ line and using meter find cross connector for connecting load / motor (usually white and black or red from the motor). The contactor has a push button to test your work (use meter to test before actually wiring up motor and line). The contactor is controlled by separate switch (usually pressure switch on the compressor) using proper voltage as required by magnetic switch of s-p40t. Good luck
Apr 06, 2014 | Puma Air Air Compressors Puma Air PK7060V...
Accidently got 220 volts for 3 seconds, then shut off. will not re-start, how should I proceed?
Look for reset button, hopefully reset would have tripped. If compressor will not power on, remove cover to pressure switch and examine contacts for burned. If burned, temp. connect 110v to motor side of switch, (black- black and white-white) if motor runs ok replace switch. If motor does not run check capacitor for proper valve, replace as needed. If cap tests ok and motor will not run check motor windings for melted white strings that bind wiring. If windings look burned most likely you will need to find used motor from repair center.
Dec 01, 2010 | Makita MAC5200 Electric Powered Air...
I have a 5,000 btu frigidaire a/c and the compressor won't kick in
Could be the starter contactor, the capacitor or the compressor by itself . You can see the condition of the starter and maybe clean or if it looks bad , must be replaced. The same goes for the capacitor if the compressor is humming. But if the compressor motor is not starting up , please check for starting current with a clamp tester, if it goes higher and stalls then the compressor/motor is faulty.
Might need help to do an overhauling.
I hope this advice helps.
Aug 20, 2010 | Frigidaire FAX052P7 Compact Room Air...
My dad bought a used 2HP 4 gallon clarke pancake type air compressor at an auction. It keeps blowing capacitors. Does it have a centrifical switch to take the cap out of the cct once started?
hi there!
some motor compressor are equipted of centrifugal switch connected at the shatfting of the motor compressor after turning at rated speed this will be open and disconnecting your starting circuit as well as the starting capacitor.
have anice day fix my rate, thank you
May 07, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Motor will not crank when air is in tank.
you are supposed to use the unloader valve to start. when air is in tank the starter motor is not only turning the motor but also trying to compress air. this very hard on the whole unit. the unloader valve should have what looks like a loose lever. lift the lever and it pulls the attached rod. after motor starts and runs put back to rest position
Nov 14, 2009 | Hitachi EC2510E 5.5hp Gas Air Compressor
Dryer button will not stay down. When you let go of the dryer button it stops. If I were to stand there and hold the button down it would stay one. While on it clicks
There is a centrifical switch in the motor that will only close once the motor is up to speed, the start button you push energises the starter winding, and once the motor is up to speed the run windings are energised by the centrifical switch.
The switch is not hard to replace but you will need the correct one, take the old one with you unless you'v got the complete model number from the motor.
Aug 14, 2009 | Dryers
ROTARY SCREW COMPRESSOR TRIPPING
Possibly water in the air tank ? Or Ice covering the inlet or screen into the tank? DOes it have a belt? or direct drive? Remove the belt and try to turn by hand. See if its the motor or the compressor is tight. If it rolls free possible a chack valve is hung up or has a broken spring OR yuo have a bad capicator or centrifical sw going to the start capicator. Check amp draw with no pressure on the compressor. tank open. If it runs extra time its somethign while under load. If it still cuts out you need to sepperate and discover if its a mechanical or electrical problem.
HOPE THIS HELPS PLEASE RATE ME ACCORDINGLY AND GOOD LUCK
Mar 03, 2009 | Ingersoll Rand Compressors 5-HP,...
Air Tools & Compressors Logo
47 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
