Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
I have a Gaggia Evolution expresso maker about 8 years old. When button is pressed to start motor it just hums and no hot water comes out. The motor only runs if I open the steam outlet
  • colin776 Jun 30, 2009
    I cannot get access to the inside of the machine so I presume I need some sort of cleaner that may solve the problem
  • Ernest R
    Ernest R May 11, 2010
    Have you tried to clean out the brew unit screen and tube?
    President:
  • 1,618 Answers
Try this, under the grouphead, there is a screw and screen, remove those, and check screen to see if it is clogged, when screen is removed press button to brew, if water flows freely then problem is at the screen, if no water flows, then it is on the inside of the machine. You will have to run a descale cycle to clear out machine. Check the folling pic for the screen location.I have a Gaggia Evolution expresso maker about 8 - 2722dbe.jpg
Posted on Jul 02, 2009
Gaggia Evolution is overheating
Check the thermostat on the side of the boiler, that might be damaged.
Apr 11, 2010 | Gaggia Evolution Espresso Machine
The pump does not run water through the filter head. It makes a noise and pumps the hot water back into the water tank
Almost certainly due to the reverse side of the brewhead being scaled up. The evolution has a recess on the reverse of the head that block causing no water to come out. Remove the head and clean it off.
Dec 31, 2009 | Gaggia Evolution Espresso Machine
When the hot water switch is pressed, no water is pumped.
group head is blocked. remove centre screw from the group head remove spring and valve, clean and re assemble.
Sep 20, 2009 | Gaggia Evolution Espresso Machine
Gaggia Evolution Espresso won't heat up
1 heating element defect(needs replacement)
2 security termistat, (replacement or reset)
Mar 25, 2009 | Gaggia Evolution Espresso Machine
Gaggia evolution not producing coffee
One question before I make any suggestions: If you remove the shower screen and screw, do you get a nice flow of water or is it still steam?
If you get a nice flow of water, then check your screen hold it up to the light and you should be able to see through the tiny holes, if not, get a pair of needle nose pliers and being very careful hold screen over an open flame like the stove burner. The coffee will burn before the anything happens to the metal. When it is cooled screw into group and see if the flow of water is better.
If you get nothing but steam then it is time to descale the machine.
Feb 27, 2009 | Gaggia Evolution Espresso Machine
Hot water
Have you kept up with descaling?
Probably the water heater has failed. If you're technical then most parts should be replaceable but you may have to order them from Gaggia in Italy.
Oct 30, 2008 | Gaggia Titanium Espresso Machine
Pump problem on a Gaggia Espresso Evolution
You need a bellows pump or similar, when you start the pump you need to set the pump to the water inlet and press in the water with force.
Jul 09, 2008 | Gaggia Evolution Espresso Machine
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
454 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
