Question about Panasonic TH-42PX60U Television
It just went off itself
This device has stopped working today @ 10PM; it just went off itself and never responded to any attempts to turn it on. I have checked a power cord and outlet and all other possible things - all look ok.
Manufactured: December 2006
Purchased: April 2007
  • oleott Jun 27, 2009
    No I cannot see any lights blinking or other things which could indicate some presence of life in this device
    Ok I'll try
  • 297 Answers
Do you see any blinks of the power light?
The power supply board must be probably replaced in this case.
Posted on Jun 27, 2009
  • sabharish
    sabharish Jun 27, 2009
    Then its obvious that the problem is with the Power Supply Board. Replace it and you are done!
  • sabharish
    Ok, I hope to save you a lot of money. Order the 2 fuses for the main
    power board from panasonic. The fuse number is K5D802BNA005. You only
    need two. Once I changed the 2 fuses I go the tv to power up but the
    red light blinked 10 times. This indicated there is a power problem.
    There is a high probability the Power supply board is bad. You can check this by
    checking the voltage on the number one pin on the p10 connector. To do
    this you have to measure the voltage as you power the TV up. you should
    get 14 volts. if not the board is bad.You can get one on Ebay for $120.
    Put it in and it will work. good luck.
Not responding
Blister, is the A/V not responding to both the receiver's buttons and remote control?
Aug 30, 2017 | Harman Kardon AVR 435 Receiver
Unexpected error.error code 11
Code 11
An attempt was made to load a program with an incorrect format.
Windows stopped responding while attempting to start this device, and therefore will never attempt to start this device again. (Code 11)
If you had install a device, Resolution
This error occurs when the computer stops responding during installation. It's a problem with Windows. To solve it, remove and reinstall the adapter.
Try upgrading the device drivers for this device.
Hope it helps.
Aug 12, 2010 | Computers & Internet
Remote does not work right at certain times of the
Hello massce. My name is Michael Hurst with DISH Network. I see that you are experiencing issues with your remote during a certain time (7pm-10pm). Seems like there is something that is interfering with the signal that the remote is sending to the receiver, what could be causing this issue could be, backlighting or power save mode on LCD TV's, fluorescent lighting in room, or direct sunlight. You can go through an elimination process by turning on your TV and the DISH receiver then slowly turning on other components in the room. If there is a component in the room that makes the remote stop working that would be the cause of the issue. If the component can't be found an upgrade to UHF remote may help remedy the issue so it doesn't continue.
Jun 16, 2010 | DISH Network IR Remote Control
Touchpad stopped working aon my laptop
Have you tried updating the device?
My Computer,Right Click, select Properties,Hardware, check the devices drivers and update them. There is also a troubleshoot device option here.
Check in the control panel to make sure the touchpad is not turned off. It can be found in the mouse option.
If you go to Start All Programs, Control You can check for any problems here
Feb 17, 2010 | Compaq Presario CQ50-215NR Notebook
LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
Jul 01, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Tv won't turn on or respond
if its a sony bravio LCD the backlight inverter failed
Dec 06, 2008 | Televison & Video
Printer stopped printing says not responding
Just go to printer icon on tray after print attempt, and clear print queue, it may be confused with unsent jobs. Clearing this should help. Try turning it off and unpugging it, then replugging and on again to reset itself. Failing this, try a compete unistall and reinstall. Cheers lilacgerry
Jul 31, 2008 | Lexmark X1270 All-In-One InkJet Printer
My T.V is turning itself off after 2 seconds where you can hear sound but there is no picture
Hello according to the symtom that you have describe I think that maybe you have activated the sleep function button on your tv and if this is not so maybe there is an internal problem on the main board of the tv.
Jan 10, 2007 | Sylvania 6413TD 13" TV
Panasonic TH-42PX60U Television Logo
159 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
