Question about HP Compaq Presario SR2020NX PC Desktop
I have a similar problem my computer sr 2020 nx compaq turns on with green light and my fan is at full speed making tons of noise which usually doesnt... and my moniter wont react to the desktop for some reason mouse and keyboard either only the desktop is on,.
  • 615 Answers
1.Clean the RAM twice.
2.If No display then Check with another RAM
3.If it also fails disconnect all the drives and clean the processor slots.then check again.
4. If it also fails may be problem with SMPS or Mother Board
Posted on Jun 27, 2009
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
I have two compaq desktop computers i usually switch from one to the other for personal preference. Anyways i plugged my 2nd computer in and it worked fine, when i go to change the cords (power supply,...
Your computer is not POSTing, the best solution is to get warranty support on it.
The other option is to take it to a computer technician and he/she will diagnose the faulty component. They have access to many computer components and can determine the fault by a process of elimination.
damnor01
Jan 30, 2011 | HP Compaq Presario SR1230NX (PJ518AA) PC...
My daughter plays World of War Craft all day! I want to help her upgrade her computer... So what is the best video card to get for a compaq sr 2020 nx?
Graphics Controller
  • Type Integrated
  • Graphics Processor / Vendor NVIDIA GeForce 6150 LE
  • Video Memory 256.0 MB (max)
Upgrade your vbideo card more thant 512mb minimun 1gigas is the best.
also upgrade your memory ram
Dec 19, 2010 | HP Compaq Presario SR2020NX PC Desktop
I want to hook a tv to my computer compaq presario model # SR 1420 NX how do i do it
You need a TV Tuner Card. Either an Internal or an External one.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1313&_nkw=tv+tuner&_sacat=See-All-Categories
Aug 28, 2010 | Compaq Computers & Internet
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
We get a blinking green light response where the ''On'' button is on our Compac presario SR 1111 NX and cannot get the computer to turn on. Is this a battery problem of some sort? Can I fix it? The...
take out all the cables from the back of computer,press the power button for 1 min and then plug in only keyboard,mouse,monitor and power ,it will work
Feb 09, 2010 | Computers & Internet
Can Air Handler !1/2 ton run with 2 ton
Its done all the time. It is sometimes better to do this because you run a colder coil and rmoves more humidity. The newer unit have variable speed fan and run slower to do the same thing. Remember the lower the humidity the higher you can raise your tsta. Example In arizona at 95 degrees you dont feel the heat as much because of the lower humidity. Its ok to do so. You get more btus out of your unit that way. Rus. I have dozens of units with air handlers 1/2 ton smaller...
Jul 18, 2009 | Dometic Rooftop RV Air Conditioner
North gate computer hard to turn on
hi, how is the heatsink compound between cpu? also check the bios, make sure it is set right, bus speed, ect. you can download it if you know the brand of mainboard. and the power supply could be on its way out. contact me for more help,if this info does not help. does it just die when on for a while? or when under load? isthe cpu fan woking ok? you can download speed fan free to see. good luck hope this helps,good luck!
Mar 06, 2009 | AMD Athlon XP-2500 1.833GHz 512K 333MHz...
Flashing Green Light on Power Supply
get yourself a themaltake ps
make sure you remove the old one and take it with you to the shop or get the shop to do it for you if you dont have the expertise yourself.
hope this helps
Dec 31, 2008 | Compaq 300Wt Presario ATX Power Supply...
HP Compaq Presario SR2020NX  PC Desktop Logo
345 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
