Question about SNK Washing Machines
Not agitating or spinning
Simpson espirit 650 not agitating or spinning
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: simpson washer only agitates in one direction
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
rickead1
  • 1998 Answers
SOURCE: Please describe your Simpson espirit
hello can you please describe the problem your having with your simpson as well as repeat the model number as well the j*01 is this supposed to be a space Thanks again Rick
Posted on Jan 05, 2011
How do I remove the agitater from simpson washing machine espirit 550 5.5kg
most machines with verticle and turning agitators have a cap on the top which may be removed with a small ***** driver. that should give you access to dawgs and release nut. use a rubber hammer to gently tap and loosen if need be.
Apr 03, 2016 | Simpson Washing Machines
Hi, I am Hoping for a Service/Repair Manual for a Simpson Espirit 450 Top Loader. I think it has Shorted out and needs rewiring or a fuse replaced(If they have Fuses)
I went google and typed in-- workshop manual for simpson espirit 450 top loader washing machine -- and got several pages one of which is www. manuals. club
I suspect that you may have to pay for the manual but on their page there is a listing for user manual, installation manual, service manual, parts list and schematics
try and see if you get what you want
there may be a loose connection to the program board or a faulty program board but I doubt that you will need a rewire or anything drastic like that
Dec 07, 2015 | Simpson Washing Machines
Simpson esprit 550 agitator & spin not working properly.
Open the lid during the wash cycle and observe the agitation, you need to see exactly whats happening, If its corkscrewing instead of agitating it will wind the clothes as you described. Agitation is usually back and forth, or up and down etc, not just turning constantly in the same direction.
Aug 25, 2014 | Washing Machines
Operating instructions for 36P450 Simpson washing machine
I have a Simpson espirit 450 andthe agitator has a hole. I have beensent a new one but have no idea how to remove the old one. I can loosen the bolt at the bottom but can't can remove the bolt. Unsure why or what to now ? Would love some help... Thank you
Dec 01, 2010 | Washing Machines
Simpson eziset 750. During the wash cycle, it does not agitate in both directions, it will only turn in one direction, then stop and pause like it wants to turn in the opposite dirction, then turns in...
Hi just read your posting.Depending on how old your machine is it could be a couple of reasons.1st thing I need to know is how old your machine is? Also when the machine should turn the opposite direction listen carefully and do you hear a hum from the motor when it should be turning in the opposite direction?Please reply with this additional information and I am sure I can help you .Looking forward to your reply.
Oct 14, 2010 | Washing Machines
A necklace has dropped down under the agitator in my Simpson Espirit 700, how do I get it out. Thanks - ****
Hi just read your posting.Now do you still require help?If you do then pull the middle of the agitator out and shine a torch down the center.You should see a 10 mm bolt.Grab a socket set and turn the bolt anticlockwise to remove it and then lift the agitator out.Please reply on how you got on and for more advice if needed.Looking forward to your reply.
Aug 17, 2010 | Washing Machines
Simpson Espirit water not Filling
try removing your cold water hose and check to see if the screen filter has a calcium buildup or some other obstruction.  if not that then possible bas inlet valve on washer.
Aug 03, 2010 | Washing Machines
Simpson Esprit 650 - Won't agitate
Our machine , same model, was doing the same. Had a repairman cone out & it was the Motor Control unit, seems to be a fairly common problem. But now its fixed & working well.
Dec 27, 2009 | Washing Machines
My simpson espirit 700 has been in storage for
check first the continuity of the power cable. next is the fuse if it is not busted. then try to open the control portion there might be some coroded contacts.
Apr 07, 2009 | Washing Machines
Washing Machines Logo
Top SNK Washing Machines Experts
Are you a SNK Washing Machine Expert? Answer questions, earn points and help others
