Question about Epson Stylus CX3200 All-In-One InkJet Printer
CX3200. When printing A4 document in normal mode, it starts correctly then after maybe half a dozen lines there's much clunking and whirring and the print realigns itself more to the centre of the page, leaving approx 6-7cm on the left margin. Whilst doing this it makes frightful noises like its self destructing. Any Ideas??
  • daverhodges2 Jun 29, 2009
    wow, cleaned the heavy ink traces across the guides and it runs sweeter than when new. Thanks to SALES320 for your input, I now know a man who can!!
  • 526 Answers
It could be one of 2 things, your carriage shaft might be dirty and needs lubricating. when the printhead goes left and right, if it has to work hard to do it, the part that holds the belt could be releasing tension causing a noise. another possibility is the screw that is holding the part that holds the belt is loose and needs tightening.
Posted on Jun 27, 2009
My epson xp-435 keep running out of ink after half a dozen prints. My ink just doesn't last and we always buy epson ink cartridges.Its costing us a fortune in ink. Jose.
Check your settings. If you are printing photos and are printing them as glossy you will go through ink quickly. If your just printing text documents look at your menu on the printer to look for an eco mode that uses less ink.
Jan 19, 2017 | Epson Office Equipment & Supplies
My cx 3200 is not printing correctly. It prints
I had that same problem, when I used Generic INK.
Replace the cartridges with Genuine Epson Ink,
and then ran fine.
Weird eh?
Good Luck.
Nov 04, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Audi a4 whirring acceleration noise
Hi i have 02 audi a4 slimline. on motorway going 70 mph and to past a car dropped it down to fourth gear probly hit 90mph. Drove for a further hour and a half, and hear a bang under car. car started to loose power. was drivable but hissing noise come out of it when accelerating. Feels like turbo not kicking in. Would this be that the turbo has blown of maybe burst pipe or something. If anyone can share a light on this i would be very greatful. Cheers
Aug 02, 2009 | 2003 Audi A4 Cabriolet
Canon PC-D320 prints only left half o document with closed cover
I had the same problem but it was caused by the scanner that was not running flash under the copier glass,if I remember correctly there are spacers on the scanner that keep the scanner to run exactly the same distance from the glass of both sides of the scanner.
On the other machine,I found a faulty scanner cable that cause a similar problem.
Jan 30, 2009 | Canon PC-D320 Copier
Epson stylus photo rx420
Move envelope/A4 lever near paper output tray until the letter L registers on display. Print in this mode and you should have full page printed.
Jan 21, 2009 | Epson Office Equipment & Supplies
Printing problems Kyocera KM 2050
try setting the driver to KPDL mode in the settings section of the driver
May 07, 2008 | Office Equipment & Supplies
Right half of A4 has not print correctly
How old is the printer? try to go to the print options and do a realignment of the print heads. if its an old printer possible might need to clean the print head if that didnt work maybe bad print head.... take it to the pro. good luck!
Mar 21, 2008 | Canon BJC S300 InkJet Printer
Epson CX3200 is Clunking and misaligned
You need to start by cleaning the head from the underside. This rescue kit has a good cleaning guide as well as loads of other useful info and functions.
Dec 04, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Printing an A3 document on an A4 printer
Set your paper size to A3 - it should print out the docs on two seperate sheets of A4.
Oct 11, 2007 | Konica Minolta Magicolor 2450 Printer
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
Epson Stylus CX3200 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
