I have purple heads on my tv - Televison & Video
  • 1,056 Answers
Maybe you have some kind of magnetic material on top of the TV. TV screens respond to magnetic field. If the problem is not caused by a magnetic material being near it, then it is the degauss (meaning demagnetize) circuit inside. You can also degauss a screen using electromagnet. If placed around the screen of the TV in the right way. I have never used a magnet to demagnetize a TV screen, but maybe orienting the magnet at just the proper angle may also demagnetize it by cancelling the magnetized area. You can also make a TV screen demagnetizer using a loop maybe made out of plastic tube and winding enamelled wire onto it. The loop has to be about the size of your TV screen. Make sure you put tape over the whole thing, and connect a plug so you can plug it to the ac outlet. Once plugged in, the ac current will produce magnetic field to cancell out the magnetized area, when you wave the loop around your screen. I once made this as one of my tools when I worked at a TV repairshop.
Posted on Jun 27, 2009
My pictures are printing with a purple hue. I
You still have some clogged heads.Head cleaning once is sometimes not enough to clean your heads properly, especially if you are using 'compatible' ink cartridges. You need to clean your heads again, and possibly still again, until your test print pattern produces the correct colours.
Jul 10, 2010 | Canon I960 InkJet Photo Printer
Want to pair existing motorola blue tooth head set with new phone, but can't get headset to go into "pairing" (purple) mode.
The center button must be depressed with boom "closed" until it turns purple. Once it is purple, let go of the button and extend the boom. It should then remain a constant purple color and then be in "pairing" mode.
Aug 28, 2009 | Motorola Mobility H700 Wireless Headset
Installing an aftermarket head unit into a 1994 Ford Bronco
are you using and after market harness to go from your bronco to the harness to the new radio. if so make sure all the colors are matched up (e.i. purple to purple, purple/black to purple/black). did the speakers work before the aftermarket unit. Also check the wiring at the oem speakers
Dec 28, 2008 | Scosche Industries Scosche Slc4 Speaker...
Screan turned a shade of purple
I believe you have lost the green channel leaving only the red and blue. It could be an internal connection like a solder joint or connector, or it could be component failure from the CRT to an adjustment pot. Being the set is ten years old it wouldn't be worth spending a lot of money on it. You can buy a 27 inch TV now for almost what a repair would cost. If the picture was very good before this probem you may try to get it fixed cheap. Otherwise it probably wouldn't be worth it.
My 27 inch TV's (A Sony and a Sharp) are pretty old and I would fix them myself if the picture tube was very good.
This may be a very good time to buy considering the discounts being offered. ;-)).
Nov 21, 2008 | RCA Televison & Video
PURPLE LINE
if the purple line comes on when your watching tv just unhook any game system hdmi cords or high definition cords other than your cable tv cords
Aug 23, 2008 | Televison & Video
Purple blotches
Ok, so I'm about to flip a lid with my TV. I am showing purple quater sized blotches all over my screen. I bought it for a discounted price because of this issue, in hopes i could fix it. I took the back panel off the TV. ( about a 6in * 6 in plate) removed the light bulb and cleaned the bulb and lens, where the light bulb faced. I used a dust cleaner and special cloth. NOTHING! I took the entire front screen off cleaned it and then cleaned the mirror and second lens.... NOTHING! Then i heard that dusk sometimes gathers behind the lens and that should be cleaned. Try this, Its 4 screws, just be careful and remember the way you took it out, because it has to be replaced the same way.
Lindsey <3 AZ
Nov 28, 2007 | Epson Livingstation LS57P2 57" Rear...
Screen turns purple
Loss of green = purple!....Please give model # and age from
back of set ........T.
Oct 27, 2007 | Televison & Video
Purple printing
I have the same problem. Just spent £50 on a new print head which did sod all. I suggest using an maintenance hammer then buying another printer.
Nov 29, 2006 | Canon PIXMA iP4000 InkJet Photo Printer
Televison & Video Logo
236 people viewed this question
Top Televison & Video Experts
