Press "end of cycle" button for over 5 seconds, the child lock comes off. Press it again and the child lock comes on, this works for Hotpoints, you could try, no harm. If it works, pl rate me.
H20 does indicate a problem with water suuply, if you are satisfied that water is present at the inlet valve, then I would suggest that the valve is faulty, or is not getting a power supply ot it.
You need to determine if the valve is getting power witha test meter.
F01 - Short circuit motor triac. most of the time this means you need a new control board. thing to try is to reset machine by switching off at plug for 5 mins then plug in and try again. hope this helps.
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off. Your machine should now work. hope this helps.
breather blocked so machine cant tell if it's full with water,door switch could be faulty that would do the same thing, or worsed case would be the programmer
