These are the codes most likely to work for a GE URC and a Magnavox SDTV.
Your remote will only use 3-digit codes or 4-digit codes, and not both.
004, 008, 009, 062, 068, 069, 074, 075, 076, 077, 089, 133, 141, 163, 165, 226, 288, 456
0062, 0004, 0009, 0456, 0183, 0226, 0288, 0008, 0068, 0075, 0141
1. Manually turn on the device TV.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the TV. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off. If it turns off after 004, it uses 3-digit codes only. If not, enter a 1 for code 0041, which will not work, and go to step 2 for 4-digit codes.
5. Aim the remote at the TV and press the POWER button. If your device does not turn off, go to step 2 and try the next code.
(6. If none of the codes work, please reply.)
SOURCE: help with GE universal remote control need code for magnavox TV?
Try this link and select the RCR451 and try the codes for it, if they do not work try the one for the RCR 460 one. Just scroll to the bottom of the page and look for the word next, click it and you should see the 460 on the bottom left.
SOURCE: I have a urc-4330B03 Big Easy remote and need the
I can not find a code for my tv in one for all my tv is apex
SOURCE: is there a code for my directv remote that will
The following code is the most popular for your brand.
00724
Setup Instructions
