Question about Drive Medical Mini Phantom Three Wheel Compact Scooter Blue - 1 each
I have a pride legond and its painfully slow. i have lppked for the pots but so far no luck. would help if i knew where too look. thanks jtff
  • 175 Answers
Http://www.pridemobility.com/contact.asp Here's the contact link for Pride Mobility. If you bought the scooter used, it may have been reprogrammed by a dealer for a slow maximum speed and not the pot at all. You need a programmer to access the controller and reset the max speed setting to 100% and clear any user profiles from the former owner. Usually when the pot goes out, it is completely dead, or will only operate at one speed, or will operate off and on.
Posted on Aug 28, 2009
I have a 2008 pride gogo elite traveller plus that has a throttle potentiometer error. I have opened upthe control panel i have the part dwr9983h008 but i cant find a replacement.
You can get parts from the Pride website.
On the pot itself, there should be the value in ohms so you may be able to find one at a Radio Shack or some other electronics parts house.
Jan 22, 2017 | Crock Pots & Slow Cookers
HOW MANY OHMS SHOULD GO THRU PRIDE CELEBRITY X CONTROL ?
I have a Pride Legend XL. I tried to get the wiring diagram, but
Pride USA would not give it to me.
They told me to call the dealer instead. I had a problem with reverse throttle creep, where the brake would not engage and it kept rolling back on me.
Had to call the local dealer to do the intial trouble shooting
(who knew exactly what the problem was) to the forward reverse throttle control pot.. I was able to order the throttle pot and replace it myself.
The problem is that Pride uses some potted modules in the tiller
and the control area, although you can find pretty much
all the parts for Pride from monsterscooterparts.com,
they don't have the wiring diagram for mine either.
I am disappointed in Pride, who want to keep their
service manual with the wiring diagram a big secret from
the owners and only the dealers have it.
Oct 19, 2014 | Pride Health & Beauty
Go go ultra
hi, okay if it's the loading effect on the batteries, not a loose connection, then look at the speed pot, when it slows down try pushing the lever upwards or downwards, improves then the pot needs replacing , this is a simple test to see whether the tracks within the pots are worn...
Regards
Rob
www.gewizrepairs.co.uk
Mar 03, 2014 | Pride Mobility Products GoGo Ultra X...
My Pride scooter bought in '97 doesn't run
Hello, my name is Mike.
Here is a couple areas that would cause this:
A faulty throttle pot ( Wig Wag ). I have changed many throttle pots for this reason.
Also check battery and motor connectors. Sometimes even if the meter is not dropping poor batteries can cause surges which would cause this. Sometimes you get lucky where you take key out, and let set for a bit. Then put key in with out depressing throttle. But that is rare this works. Most times it going to be a battery issue, or a faulty throttle pot. Best to have service place replace this if your not really mechanically inclined in electronics. Thank You , MIke.
Sep 19, 2011 | Pride Celebrity Xl 4 Wheel Scooter
Even on a full charge my classic xl8 slows down and speeds up again any sugestions please
Pride scooters are known for this problem, as I found out when it happened to mine.
You need to replace the Throttle Pot. Either take it to a mobility shop and let them do it or buy the part and do it yourself. It simply involves unscrewing the old one and screwing the new one into place, and there are diagrams to help you on the internet.
This throttle pot problem has happened to my Pride scooter three times already.
Jun 20, 2011 | Pride Mobility Products Revo (3wheel)
PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
Jul 19, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
7 bleeps on my GO GO ELITE TRAVELLER SCOOTER
Hi. 7 beeps is fault code for a faulty speed potentiometer. Might also be a broken wire on the pot or a faulty connector. Most times, a new pot will fix the problem.
Good luck. Neil.
Jul 08, 2010 | Pride Go Go Elite Traveller Plus HD 4...
I HAVE A CELEBRITY DX SCOOTER, IT IS 4 YEARS OLD. I HAVE HAD NEW BATTERIES FITTED, BUT THIS LAST 3 MONTHS THE SCOOTER RUNS FROM NORMAL SPEED TO SLOW AND SLUGGISH THEN BACK TO NORMAL EVERY FEW MINUTES.CAN...
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
Jul 05, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
Power problem
throttle pot or loose hex nut that holds the actual forward and reverse paddle, may be slipping
Dec 20, 2008 | Pride New Mobility Rally 4 Wheel Scooter
Drive Medical Mini Phantom Three Wheel Compact Scooter Blue - 1 each Logo
5,665 people viewed this question
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
