Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need handle rope - Poulan Pro 42CC 2 Cycle Chainsaw, 18"
    Brigadier General:
  • 4,088 Answers
Buy a length of cord from a servicing dealer. The trick is to wind the new cord around the pulley and maintain proper return tension on the return coil spring.
Posted on Jul 04, 2009
Lawn mower rope pully repair
if rope to long then pull out recoil one turn hold rope tight pull knot out of handle down rope rope to were you are holding it tie a knot in rope slowly let rope go back in recoil then pull it all the way out should fit now cut off excess rope but also if you have a long rope it is suppose to mount on handle should be a mount hook for on the handle
Sep 05, 2014 | Garden
I just bought the Weider Beaded Jump Rope and it is too long for me is there a way to shorten it without ruining it?
if you're careful and crafty you can try to take the beads off the rope and use a scissor to cut the rope to your ideal height, If the jump rope isn't constructed to be disassembled or you don't wanna take the risk, try tying a knot on both end of the handles to shorten the rope. btw you probably know this already, but when trying to determine the length of a jump rope you should stand on the center of the rope and make sure each end of the handle reaches your armpit or at least your chest
Jan 16, 2013 | Weider Jump Rope, Beaded, 1 rope
Broken pull chord
Remove recoil assembly from top of engine. Observe recoil wheel and find knotted end of rope in wheel, Observe direction of rope wrapped around wheel, cut knot off wheel end of rope remove rope. Rope purchased by the foot at mower repair shop. Feed new rope end into hole in recoil wheel wrap around in correct direction, feed rope thru recoil cover, remove old rope from handle, feed new rope thru handle to proper length, Knot rope to stay in handle.
May 14, 2012 | Toro Power Lawn Mower
How to replace coil string
This is best done with two people. Remove cover, place down so you are viewing the rope pulley. Remove all old rope. Measure 8 foot of new rope. line up pulley rope hole with rope opening in cover. Wind rope pulley 6 turns. Push new rope thru both rope openings, one in pulley and one in cover. Pull rope thru pulley and cover. Tie knot in pulley end of rope, Slowely release rope so it rewinds onto pulley. Install hope handle, your done. was'nt that easy? You will have extra rope, this is needed to go from engine to handle support on your mower handle.
May 28, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
How do I wind a stihl ts400 pull cord
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 21, 2009 | Garden
Starter rope pulley will not pull the rope back into the leaf blower.
Most commonly, the recoil rope rewind spring is broken. However, inspect the recoil housing assembly first to make sure no debris or rope fragments have prevented the rope rotor from rewinding. Always remove the spring 'AS A LAST RESORT'. Many rewind problems can be solved by inspection of the rotor and not have to remove the spring. In case you do, I will include instructions on how to re-install.
Nov 21, 2009 | Craftsman Garden
STEP BY STEP DIRECTION. REPLACE STARTER ROPE. MIGHTYLITE BLOWER MODEL #UT08520
Nov 14, 2009 | Garden
CAN'T FIGURE OUT HOW TO RE-STRING PULL CORD
Nov 13, 2009 | Poulan Garden
I pulled the cord off my homelite 2 cycle leaf blower. can it be fixed?
Yes,
Nov 08, 2009 | Garden
How do you adjust the valeo speed jump rope for your height?
It's simple, really.
At each end of the handles, you'll see a black cap. You can use a flathead screwdriver to go right in the crack of it, and pop it out. You then take the black rope, pull it out, and move down the silver piece until it fits your height. If you're like me, you'll need to cut some of the rope so it will fit in the handle. After you have adjusted it to the right height, snap the black caps back in.
Feb 19, 2009 | Valeo Speed Jump Rope 1 Pk
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
