Question about Video Game Consoles & Games
I have ps3 when iam switch on it ic showing green big dots on the screen can you help me to fix it?
PODA PANNI
Posted on Jun 27, 2009
White and Blk dots on screen increasing in numbers...HELP - Just replaced LAMP and Spots are still on screen
This tv have a design problems with it Light Projection Engine Block.This Light Engine Block have a design flaw with the IC chip the tvs corporations they're putting it in the tvs.This problems happen to many to other tvs compannies too like Samsung,Toshiba,Sony Big Screen DLP tvs too.The whole Light Projection Engine block have to be replaced or change the IC chip.This is a very expensive fix,because the tv Light Projection Engine Block is the brain for the tv.Call them up and talk to them make a deal with them to help u with repair cost.This problems with dots apearing on the DLP tv big screen is not a new problems,have been NEW on the Youtube video site for a few years now.
May 07, 2011 | Mitsubishi LT55154 55 in. LED EdgeLit LCD...
White dots are showing up on the screen. They are multiplying quickly. I was told to clean the filter but that did not help. The lamp is less than a year old. Nearest dealer is 2 states away. How can this...
This problems is the tv Projection Light Engine design flaw with it IC chip.These problems happen to many models of it DLP tvs Big Screen 60 and up.Mitsubishi,Samsung,Sony,Toshiba all used the same IC chip on their 60 and up on their DLP tvs Big Screen.Tries make deal with Mitsubishi help u split the cost of repair the tv Projection Light Engine by replacing the IC chip or replaced the entire Projection Light Engine system.This problems is not new,been going on for a few years.Many people when on Youtube **** about this problems with white dots showing up on their tvs screens and multiplying rapidly.
Nov 20, 2010 | Mitsubishi WD-73734 73" Television
I have a panasonic PT-47wxc43 projection tv. I have green and purple halos coming up from the bottom. The screen has purple and green double images which are worse from the bottom up.
This problem is due to convergence output ICs failure and both chips will be replaced to fix the issue.
There are two big black ICs installed with aluminum heat sink on deflection board, these are convergence output ICs and will be replaced to correct the problem, it is common problem of rear projection tv.
Below image of deflection shows ICs (marked in red) that are need to be replaced.
IC number is STK392-110 and available with Part Store for $32 each.
Click above link to see an image of IC.
If you are handy with electronics stuff repair and can replace parts in tv circuit board then can replace these parts yourself or ask local tech to help you.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
May 25, 2010 | Panasonic PT-47WXC43 47" Rear Projection...
Ps3 had red screen error, replaced hd and updated, still has red screen error. when i try to turn it off it beeps 3 times and the green light blinks constantly doesnt shut off.
These articles could help fix your PS3 again.
<a href="http://ezinearticles.com/?Have-You-Got-Issues-With-the-PS3-Red-Flashing-Light?-Fix-This-Problem-Today&id=3629324">PS3 Red Flashing Light</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-Fix---Quick-Guide&id=3512073">PS3 Red Light Fix</a>
<a href="http://ezinearticles.com/?PS3-Blinking-Red-Light-Problem-Solved---If-You-Have-This-Problem,-You-Really-Need-to-Read-This&id=3512063">PS3 Blinking Red Light Problem</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-of-Death---How-to-Fix-it-Quickly-and-Easily&id=3512067">PS3 Red Light OF Death</a>
<a href="http://ezinearticles.com/?Thinking-About-Buying-a-PlayStation-3-Repair-Guide?-Then-You-Better-Read-This-Before-You-Do!&id=3676847">Playstation 3 Repair Guide</a>
Feb 10, 2010 | Sony Playstation 3 (PS3) Console
I have a samsung 46" which does not show the picture.
Replace Both of your STK ICs they are big black IC will have part # on them example STK392-110 also 2 resistors low ohms 2.7 ck them Call Mats for Parts 1-800-628-1118
Sep 22, 2009 | Samsung PCH521R 52" Rear Projection...
Screen freeze, with green dots!
Its a small group of solder balls 3-4 under the GPU that
have broken in to thhreads , and will disconnect all together
from the main board , it some time will start with a flickery
screen during start up .
The only permanent solution is to dig a hole.... just kiding
The GPU will need to be re-flowed and properly secured to
the PC board .
That fixes the problem permanently
and that goes for 98% of all of The 360s problems
Aug 24, 2009 | Sony Playstation 3 (PS3) Console
When PS3 boots the screen turns green with white dots
Emergency cooling should be cleaned. If not cleaned, you risk expensive repair.
Oct 24, 2017 | Sony Playstation 3 (PS3) Console
My panasonic pt-61lcx has green dots on the screen)
sorry but it's the bulb.....hince why there is a class action lawsuit against them......
Feb 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
TOSHIBA 65H82
you need to replace your 2-convergence ic's #STK392-110 you need to replace both ,,they are attached to 2 big heat sinks and identified as q-751 & q-752 you can get the ic's you need plus free tec support and installation instructions including pictures at the link I gave you.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Toshiba 65H82 65" Rear Projection...
Video Game Consoles & Games Logo
63 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
