Question about Microsoft Xbox 360 Console
Red lights was playing 360 fine untill 3 red lights came on and now it won't even turn onb
  • Anonymous Dec 25, 2007
    My X-box 360 keeps blinking a red light on the on/off button. I think it is becasue the hardrive will not stay in its place. I have already tried putting the hardrive in 100 times and it stills does not work. How do i fix this?
    Guru:
  • 155 Answers
Please read http://en.wikipedia.org/wiki/Xbox_360_technical_problems
and if this is what it is then you have serious problems.:-(
Posted on Nov 06, 2007
Had the box 360 60gb for 3 weeks. Been running it via the tv scart option with yellow wire and audio red & white. Worked for 3 weeks until during playing Assassins Creed Brotherhood the screen went...
Maybe someone stepped on your cables try getting different cables.
For example if your tv is hd get a hdmi cable or buy another set of those cables.
Maybe it will help.
Jan 04, 2011 | Microsoft Xbox 360 Console
My xbox 360 works fine playing the games that are demos
there might be a short.
other then that i might just think that your power adapter is failing and you need another one.
Dec 01, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
Shuts off randomly.
do red lights show up? if so look up red light errors ten ask about a fix for that specific error.
Nov 28, 2009 | Microsoft Xbox 360 Console
My xbox controllers will not charge with the plug in kit. The light turns red, then either immediately green, or it starts to blink red-off-red-off.
I had the same problem. The Battery pack on mine was dead for a long time as i havent touched my Xbox 360 in a while. So
SOLUTION
Step 1. Plug the play and charge cord into the controller
Step 2. If Light turns green within a minute or so, Unplug the play and charge cord and go to Step 1 (Repeating this process until the light stays red on the play and charge cord (3-10 times))
Oct 08, 2009 | Microsoft Xbox 360 Controller
My elite has works but the video doesnt, even with light on cable
turns out after a bit of fiddling around that there is a switch on the 360 elite's VGA cable that you can switch on and off, i never knew they had these switches because it is my first tme with an elite, machine works fine though so far no freezes or glitches and im playing fallout 3. anyway for allthose that cant get video because of the cord or something make sure you check your VGA TV/HDTV switch, as i missed it too.
Jun 13, 2009 | Microsoft Xbox 360 Elite Console
My xbox 360 it has the 2 red lights flashing
The two red lights means it's overheated. One let it cool down, don't turn it on until it had good while to cool. Two give your 360 more ventilation room. If that's not enough buy intercooler for it. Remember just give it some room to breath. Get more cool air flowing through it and it should be fine.
Mar 24, 2009 | Microsoft Xbox 360 Console
Xbox 360 error 73
Sometimes the easiest way is the fastest way. The signal reset button (the little one to the left of the power button) is also the unofficial reset button for the Xbox 360. With the Xbox turn off, press this button and keep pressing it while you press the power button. Do not release the reset button until you see the system booting up normally. Of course, if there is a permanent or a more serious damage to the system, it won’t work or the error will be recurrent until it is solved. Resetting just clears the error from memory.
Dec 09, 2008 | Microsoft Xbox 360 Console
Was playing Tiger Woods 09 on my 360 when the graphics all of the sudden looked very cheap and generic. I played a few more holes and then shut it off. I tried to turn it back on after about 5 minutes and...
Sounds like the infamous Xbox 360 "3 flashing red LED's" issue, ours did the same shortly before suffering 3 flashing red LED's. If you have one of the original Xbox 360's (without an HDMI port on the back) every single one was built with the wrong solder, so when it gets hot enough the solder melts and your graphics chip gets disconnected.
Is mad as it sounds, run the Xbox 360 for a bit longer until it dies completely because Microsoft have extended the warranty for that specific issue to 3 years! Once you have 3 flashing red LED's you can call the help-line in your country, go through a few diagnostics with them and then (and only then!) the call agent will tell you that as long as your Xbox is less than 3 years old it will be repaired for free.
Microsoft have not widely advertised this and indeed if you try to book service on line it will tell you that you have to pay, even if you click yes to the question "Does your Xbox 360 have 3 flashing red lights on the front?".
However, if you have a newer Xbox 360 message back and we'll go through further diagnostics.
Nick. :)
Nov 06, 2008 | Video Game Consoles & Games
X Box 360
This exact thing is happening to not only me but to also a friend of mine. You will probably notice that the fan kicks on really high and then goes to 2 flashing red lights, this is because the 360 is overheating or thinks its overheating. My friend's 360 starts up with the fan kicked on high and then only plays for a minute or 2, followed by the 2 red lights. If its under warranty send it back to Microsoft, I took mine and my friends 360 apart and replaced the thermal paste with arctic silver, but it kind of only helped a little for mine and not at all for my friends. SEND IT BACK!!!!!!
Aug 30, 2008 | Microsoft Xbox 360 Console
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
