Question about ASUS Computers & Internet
Wireless key does not work
I have ASUS PRO 50G. I use wireless, but the FnF2 key did not work. Therefore i reinstalled the vista. Now i cannot find the wireless driver, even the FnF2 does not work. So i have not any idea what is wrong and how can i use wireless again. If you have any idea please let me know. I truly appreciate it.
  • Alex Howard
    Alex Howard May 11, 2010
    Does your laptop computer have a button underneath the machine, which enables or disables wireless? Some HP Laptops have this kind of thing and, unless you turn it on, the Fn key combinations will do nothing.
I cannot turn on wireless for asus k52j, Fn and F2 key does not work
Usually the people might have problem related to asus laptop because of wireless driver. so you need to unisntall the wireless driver and reinstall it. your wifi will start working fine. hope this will help you better. for more information you can visit : Tech Support For Asus
Apr 13, 2012 | ASUS K52JT-XT1 Laptop Computer - Intel...
I have asus notebook x83 and i can not get my bluetooth device to start working. I have Vista as OS.
Hi Friend,
1. PRESS FN-F2 and check whether bluetooth is on
2. Check in My Computer Properties - Device manager whether Bluetooth Hardware Detected
3. If it is Showing then Reinstall Bluetooth Driver and wireless console utility from http://support.asus.com
Please first install the Wireless Console Utility before BlueTooth installation
Feb 21, 2010 | ASUS Eee PC 900 Notebook
Cannot turn on wireless lan with fn+f2 keys
1. first turn on the "wi-fi/wireless" switch on ur laptop manually.
2. now use the key combination for wi-fi/wireless
3. if it still not working, reinstall the wi-fi/wireless driver again, and restart ur system
Jan 01, 2010 | ASUS F6A-X2 PC Notebook
ASUS N50V FnF2 stopped working.
Dun worry. I experienced that before.. There is a physical wireless slide switch at the right of the indication light. switch it on first and see if it works.
Aug 07, 2009 | ASUS N50Vn Notebook
Wirless connection
Try turning off your personal firewall.
Dec 25, 2008 | ASUS Eee 4G Notebook
Wireless fails to work after reinstalling XP SP2
Hey there,
The wireless driver might only work on Vista, try the IT Administrators - Intel® PROSet/Wireless WiFi Connection Utility for Windows* XP and Windows Vista*from here
First uninstall the one you have though..
Hope this helps
Chris (ziraffa)
Sep 10, 2008 | Intel PRO/Wireless 3945ABG Network...
Asus 802.11 a/b/g wireless adapter problem
The problem could be with the wireless network that you are trying to access, or it has something to do with you wireless card tcp/ip protocol.
where you using the same computer now, when you had this issue with the vista? or is this win XP pc that you have now is a different computer?
if you are getting limited or no connectivity, that means that the access point (wireless signal) is not giving you a valid IP address.
you can try to add static to your IP settings, but this will only work if you knew the IP range of that network that you are trying to access.
please provide more info
Mar 25, 2008 | ASUS (wifibralinkuay) 802.11b Wireless...
I can not enable wireless security it will not save my settings on a edimax Ar7024
First things first!
hello
1) did you reinstall the OS?
2) what OS you have? VISTA? XP pro?
3) if any other wireless aplication running?
4) download a new version of wireless program for your particular wireless card. IT SHOULD WORK and save settings.
Good Luck
Mar 21, 2008 | Computers & Internet
Computers & Internet Logo
172 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
