The best way to change your security code is to contact mobile repairing shop.There they can generate the current or they can reset it to nokia default.But first of all you can try 12345.good luck
I think unlock codes will use for your mobile problem.. I got my Blackberry mobile code from here
http://www.mobile-unlocker.com/
- This is an
unlocking website. Please view the website to get more info @ reliable costs
You can use the access codes described in this section to avoid unauthorized use of your phone. The access codes can be changed by using the Change Codes menu (Menu #.2.6). Security code (4 digits) The security code protects the unauthorized use of your phone. The default security code is set to ‘0000’ and the security code is required to delete all phone entries and to activate the Reset Settings menu. The security code default setting can be modified from the Security Settings menu.
call ur customer care (aircel,airtel...etc)...then give ur last 4digit
number of ur sim card ...after tat they ll give ur puk code...used tat
code and open ur security
HI I HAVE A NOKIA 2630 IT IS LOCKED TO VODAFONE I WANT TO UNLOCK IT TO TMOBILE I ENTER THE CORRECT CODE AND IT KEEPS ON TELLING ME CODE ERROR PLS PLS PLS I NEED HELP AM I FORGOT MY SECURITY CODE MY COUSIN WAS PLAYING WITH MY PHONE AND I CANT REMEMBER THE CODE HELP ME PLS
hi,
The master code is a 10 digit number that will always be accepted as if it were your actual security code.
You can use the master code to change your security code back to what ever you like. When your Nokia handset asks you for the security code simply enter the master code.
Hello s_a_rocky, Remove the sim-card and switch on the phone .. and press this code *2767*2878# .. the phone will restore the factory settings. Thank you for using FixYa.
u might have activated the phone lock code, so go to phone settings and deactivate it, default code for nokia is 1234. if it still does'nt work try restoring factory settings.
