Good Morning Friend,
I understand your Electrolux washer, model# EWF1087, is making knocking sounds during the spin cycle. In researching your model number, I show that your appliance was manufactured in Australia. If this were manufactured in the U.S., I would suggest making sure that the load was balanced. Balance your wash load and if you are still having trouble, I suggest contacting the manufacturer in Australia. Hope this is helpful.
-Best Regards-
WP
SOURCE: Error code E10 on the
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
SOURCE: Model EWF1087 washing machine will not spin or
your pump impeller is blocked or fouling on something inside the filter compartment,turn machine off unscrew fiter (be prepared for water to come out),then get a long screwdriver and turn the impeller anything caught in there will free itself up,and you should be able to mremove forieghn object if impeller doesnt turn then it more than likely your pump is seized and will need replacing hope this helps.
SOURCE: Hi I have an electrolux front
Sorry to read about your problem, I hope this helps you out.
e90, means a bad connection. at the main control board.
you can try to open the machine and check a and clean all connections to the main board.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
SOURCE: My Electrolux Front Loader EWF1083 displays E20
E20 means problem draining.
Clean the drain pump filter and check the drain hose.
you can download a copy of the manual here:
http://www.electrolux-ui.com/2008/147/143581EN.pdf
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
