Question about Canon PC-940 Black and White Copier
E007 system error how sole this problem plese halp me
Cannon ir2016 xerox machin problme this show screen system error e007
  • 375 Answers
This error indicates the fuser film is not in the home postion, or the film is ripped/torn. Unless you are able to service it yourself, you will need to get a technician in.
Posted on Jun 27, 2009
How do I correct my photocopier machine Canon iR2016 with SYSTEM ERROR E007
Hi !
The error is caused when the fixing film is worn , it has a white patch that needs to be seen by the patch sensor , replacing the film will resolve the problem , as you can see on the picture below,
Oct 08, 2015 | Canon Office Equipment & Supplies
How can i reset a system error E007
Good answer here:
http://www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
<quote>
How to reset E000, E001, E003 and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
</quote>
Jan 20, 2015 | Canon IR2020 Copier
The machine shows the E007 system error what is the solution for it. machine is cannon iR2116J photocoyp machine
the error E007 means - fixing film rotation error.
If you are not a tech you must call for one. He could replace the broken part for about 2-300$.
Jun 03, 2011 | Canon iR 2016i Black and White Copier
Canon copier ir 2016 system error E007
i have canon ir2016 photocopier machine and its given me system error, and the error code is E007. i now when its happen so, its the fuser film that is worn out. i change the fuser and fix a new one but still the error is there. what should i do next to clear the error?
May 12, 2011 | Canon iR 2016i Black and White Copier
My xerox machine cannon IR 2020 shows a system error E007
Hi
you need to reinstal the firmware on your machine, And for the E007 check if the new film is rotating in the same speed as the presure roller, check if you mounted the film sensor corectly, and if the sensor is reading the corect end of the film ( it schould be the one whit a white square on it).
Pls vote me to keep me alive
Nov 23, 2010 | Canon iR 2022 Printer
My xerox machine cannon IR 2020 shows a system error E007. How can I solve it? Please describe step by step.
E007 - Fixing film rotation error
You have to disassemble fuser unit and inspect a fixing film, if damaged - replace.
The official documentation says:
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Nov 11, 2010 | Canon iR 2022 Printer
Hello the problem is in my canon IR2016 showing
That means that fixing film ( Folie ) is worn out. Replace fixing film assy.
Jun 14, 2010 | Sharp AR-M350N Copier
System error E007 IR2016 photo copier
i think the jam in the Fixing/Fuser Assy.? Because a E007 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error. Good luck sir let us know how you make out.
May 18, 2010 | Computers & Internet
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
Canon PC-940 Black and White Copier Logo
536 people viewed this question
old marine
old marine
