Question about Casio Edifice EF106D2AV Wrist Watch
Casio Edifice EFA105
Add link
5 Suggested Answers
SOURCE:
indays
  • 111 Answers
SOURCE: Shorten strap of Casio Edifice EF-518 watch
good morning ! thats verry easy to make shorter !just look the possition of arow and push the pin to out use the pointed tool and anvil to releas the pin ! thank you !god bless !....
Posted on Sep 02, 2008
mcdevito75
  • 1970 Answers
SOURCE: Casio Edifice Chronograph Ef539d1avdf Gents Watch
mcdevito75 here, You can contact Casio at 800-706-2534 Optn. 2 for a new owner manual.
Posted on Jul 14, 2010
news775
  • 699 Answers
SOURCE: how do you remove a
Have a look at the links nearest the clasp.
These should have markings on to say which are removable. An arrow or some other indication.
Not sure if this watch has press pins that go through the whole bracelet or flip up catches on each band.
Please dont forget to vote this answer was helpful.
Many thanks
Posted on Mar 01, 2011
SOURCE: Adjust-a-Casio-S-1087DY-Watch-Band
Im looking for the operating manual for the casio edifice efr -513sp watch. Stuart.
Posted on Jul 21, 2013
Change time in cassio edifice
Here is the link that includes step by step procedure including visuals.
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2711.pdf
I hope this will help you a lot
Thank you for choosing fixya.
Mar 02, 2011 | Casio EF-500D-2A Edifice Chronograph watch...
How do you remove a link off the Casio Men's Edifice 10-Year-Battery Analog Bracelet Watch #EF106D-2AV?
Many thanks
Mar 01, 2011 | Casio Edifice 10YearBattery Bracelet...
How to set my edifice EF528 manually, time setting, alarm ect...my uncle give me but eithout manual guide...it difficult for me to set all the functions.
Thank you for contacting Casio.<br /> You can download the manual direct from Casio. <br /> <a href="http://www.casio-europe.com/euro/watch/edifice/">http://www.casio-europe.com/euro/watch/edifice/</a><br /> Best regards.
Aug 25, 2010 | Casio Edifice EFA109-7AV Wrist Watch
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
    mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
    Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
    I would like to take of one section of the band, I've got a pin remover but I can't figure out how it's done...
    Click on my profile, then click on TIPS AND TRICKS. There you will find explanation how to add or remove links. Rate me, plz.
    Feb 19, 2010 | Casio Edifice EF304D-1AV Wrist Watch
    On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
    http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
    which should help you to remove the link pins safely without scratching.
    Aug 31, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
    Sep 01, 2008 | Casio Edifice EFA109-7AV Wrist Watch
    Casio Edifice EF106D2AV Wrist Watch Logo
    23 people viewed this question
    Top Casio Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Janelle Schoonover
    Janelle Schoonover
    Are you a Casio Watch Expert? Answer questions, earn points and help others
