My screen is beginning to have scratchy red colour where it should be black. Black backgrounds sometimes has 'static noise' red across it. Or photos with black & movies the black colour is this corrupt red instead. The problem goes away most times when I almost fully close the lid then reopen it or restart the laptop. I've run lots of virus checks incase it's a virus - doesn't appear to be one. What else can I do?
  • 30 Answers
If it is a lcd screen, the screen is taking a dump on you
Posted on Jun 27, 2009
Windows will not start funny screen
Try Settings / Update & Security / Reset Laptop
Jan 15, 2018 | Sony VAIO VGN-CR390N/B Notebook
Please tell me how do I get Backgrounds on my slideshow photos. Not the menu. At the moment my backgrounds are just black.
You need to right-click on any of the inserted photos when in edit mode. Go to "Background color" and choose from the palette. Here you can also choose to apply this colour to the rest of the photos in the chapter, or you can have a different coloured background for every photo if you wish.
11407336
Aug 06, 2010 | Individual SlideShow Expressions
New Bulb (30 hrs). Screen flickers after 10 minutes, color changes with green tint, then bulb shuts off.
Hi, I had a similar problem - the screen flicked through blue, green and red sometimes with a slight ticking noise. The problem seems to be that the colour-wheel is getting stuck - the first time this happened I sent it back to optoma who gave it a clean - it has happened again since thouegh and I just took the case off (you'll be able to see the colour wheel under a black plastic flap - remove the flap) I then used a cotton bud (q-tip) and turned the colour wheel whilst lightly pressing the cotton bud against the wheel - I also gave everything a blast with a can of air. My HD72i is ceiling mounted - optoma suggested putting the hoover pipe across the vents every now and then to keep the dust down. Essentially it's dust that is stopping the movement of the colour wheel.
Hope this helps.
Jonathan
Oct 21, 2009 | Optoma HD72 Multimedia Projector
Using Canon iP4600, I'm trying to print a black-and-white photo with a black background and a half-tone image in the front, but I keep getting purplish and black stripes instead of an all black background....
Hi there
Sometimes, printers use colors from the other cartridges in order to form a deep black colour. It does seem that not enough pure black ink is getting onto the paper.
Can you check that there is enough black ink remaining? If so, go to the print options of the program from which you are trying to printer the image, and set the colour output to black or greyscale only. This may be within an option called Printer Preferences from the Print dialogue window of the program from which you are printing from.
Then, print an image as a test and see if it comes out in black only this time.
I look forward to your reply.
Regards
Jul 25, 2009 | Office Equipment & Supplies
What causes the static background noise in my keyboard?
It sounds as though you have a static electricity problem in your volume pot. Although there are sprays on the market that you can use for all of the electrical switches on your keyboard which removes and suppresses static electricity, one way to make sure this is the problem is to slide your volume slider to maximum, then minimum, up and down about 10 to 20 times, if the scratchy sound begins to diminish, you knwo the problem lies there. As a matter of fact, if you do it long enough, the sound may go away altogether, although without a good spray of electronics cleaner or electrical contact cleaner (which you can find at stores like home depot or online, even eBay), the sound will return.
If this is not the case, and the scratchy static sound does not go away or depreciate, it could be your cords or even static on the pc board inside the unit. If you are confident that you can crack the case on your board without causign damage, then get a screwdriver and open the case (all screws are located on teh bottom of the unit) and give it a good spraying with electrical contact cleaner on all of the contacts and even a once over on all of the circuit boards. Do not wet the circuit boards with too much spray, rather, give them a light misting.
For areas where you plug in, like your 1/4 inputs, your midi ins and outs, and headphone jack, spray the contact cleaner inside the holes. You don't have to worry about spraying too much in these areas. Just do not oversaturate.
Hope this helps, and thanks for using FixYa
Jul 18, 2009 | Music
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Televison & Video
Wavy lines across the digital screen of DSC-V1
Can u mail me 1 photo at welcomejee@yahoo.com to understand what exactly happening with your camera?
May 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Computers & Internet Logo
277 people viewed this question
David Payne
David Payne
