Question about Garden
Gas leakage Gas is leaking on both sides of gas tank. Can't isolate where exactly. There is a small what appears to be screw opening that gas is coming from just under the blade, very bottom. Can't tell if there used to be a bolt there or plug of some kind or not. When I put my finger over this opening, and tilt it the other way, gas is coming out somewhere else on the other side. Doesn't leak if held upright, just if tilted appx 45 degrees left or right. Don't know if this is safe to operate in this condition, just discovered this recently. Any help would be greatly appreciated. Thanks in advance, David
  • 30 Answers
David, you need to go to a junk yard, and buy a newer gas tank. A temporary fix, would be to use a ton of JB weld on the leaky seams.
Sha'ul
Posted on Jun 27, 2009
Po442 code for 2002 grand caravan
this relates to a slight leak of fuel vapour to atmosphere from the EVAP system , to check undo and refit gas tank cap and clear code , then drive for a day and rescan for code , if reappears then the EVAP system will need inspecting for leakage
Jun 02, 2015 | Cars & Trucks
Tip
Things to test when checking cooling system
<p>A leak detection additive is available through the parts department that can be added to cooling system. The additive is highly visible under ultraviolet light (black light) (1). Pour one ounce of additive into cooling system. Place heater control unit in HEAT position. Start and operate engine until the radiator upper hose is warm to touch. Aim the commercially available black light tool at components to be checked. If leaks are present, black light will cause the additive to glow a bright green color.<br /> <p>The black light can be used in conjunction with a pressure tester to determine if any external leaks exist .<br /> <p><b>PRESSURE TESTER METHOD</b><br />he engine should be at normal operating temperature. Recheck the system cold if the cause of coolant loss is not located during the warm engine examination. <br /> WARNING <p> HOT, PRESSURIZED COOLANT CAN CAUSE INJURY BY SCALDING.<br /> <p>Carefully remove the radiator pressure cap from the filler neck and check coolant level. Push down on cap to disengage it from the stop tabs. Wipe the inside of filler neck and examine the lower inside sealing seat for nicks, cracks, paint, dirt and solder residue. Inspect the radiator-to- reserve/overflow tank hose for internal obstructions. Insert a wire through the hose to be sure it is not obstructed.<br /> <p>Inspect cams on the outside of filler neck. If the cams are damaged, seating of the pressure cap valve and tester seal will be affected.<br /> <p>Attach pressure tester (7700 or an equivalent) to radiator filler neck (1).<br /> <p>Operate tester pump to apply 103.4 kPa (15 psi) pressure to system. If hoses enlarge excessively or bulge while testing, replace as necessary. Observe the gauge pointer and determine the condition of the cooling system according to the following criteria:<br /> <p><b>Holds Steady:</b> If the pointer remains steady for two minutes, serious coolant leaks are not present in system. However, there could be an internal leak that does not appear with normal system test pressure. If it is certain that coolant is being lost and leaks cannot be detected, inspect for interior leakage or perform Internal Leakage Test. Refer to <a>INTERNAL LEAKAGE INSPECTION</a>.<br /> <p><b>Drops Slowly:</b> Indicates a small leak or seepage is occurring. Examine all connections for seepage or slight leakage with a flashlight. Inspect radiator, hoses, gasket edges and heater. Seal small leak holes with a Sealer Lubricant (or equivalent). Repair leak holes and inspect system again with pressure applied.<br /> <p><b>Drops Quickly:</b> Indicates that serious leakage is occurring. Examine system for external leakage. If leaks are not visible, inspect for internal leakage. Large radiator leak holes should be repaired by a reputable radiator repair shop.<br /> <a></a> <p><b>INTERNAL LEAKAGE INSPECTION</b><br /> <p>Remove engine oil pan drain plug and drain a small amount of engine oil. If coolant is present in the pan, it will drain first because it is heavier than oil. An alternative method is to operate engine for a short period to churn the oil. After this is done, remove engine dipstick and inspect for water globules. Also inspect the transmission dipstick for water globules and the transmission fluid cooler for leakage.<br /> <br /> WARNING <p> WITH RADIATOR PRESSURE TESTER TOOL INSTALLED ON RADIATOR, DO NOT ALLOW PRESSURE TO EXCEED 145 KPA (21 PSI). PRESSURE WILL BUILD UP QUICKLY IF A COMBUSTION LEAK IS PRESENT. TO RELEASE PRESSURE, ROCK TESTER FROM SIDE TO SIDE. WHEN REMOVING TESTER, DO NOT TURN TESTER MORE THAN 1/2 TURN IF SYSTEM IS UNDER PRESSURE.<br /> <p>Operate the engine without the pressure cap on the radiator until the thermostat opens. Attach a Pressure Tester to filler neck. If pressure builds up quickly it indicates a combustion leak exists. This is usually the result of a cylinder head gasket leak or crack in engine. Repair as necessary.<br /> <p>If there is not an immediate pressure increase, pump the Pressure Tester. Do this until indicated pressure is within system range of 110 kPa (16 psi). Fluctuation of gauge pointer indicates compression or combustion leakage into cooling system.<br /> <p>Because the vehicle is equipped with a catalytic converter, <b>do not</b> remove spark plug cables or short out cylinders to isolate compression leak.<br /> <p>If the needle on the dial of pressure tester does not fluctuate, race engine a few times to check for an abnormal amount of coolant or steam. This would be emitting from exhaust pipe. Coolant or steam from exhaust pipe may indicate a faulty cylinder head gasket, cracked engine cylinder block or cylinder head.<br /> <p>A convenient check for exhaust gas leakage into cooling system is provided by a commercially available Block Leak Check tool. Follow manufacturers instructions when using this product.<br /> <p><b>COMBUSTION LEAKAGE TEST - WITHOUT PRESSURE TESTER</b><br /> <p>DO NOT WASTE reusable coolant. If the solution is clean, drain the coolant into a clean container for reuse.<br /> <br /> WARNING <p> DO NOT REMOVE CYLINDER BLOCK DRAIN PLUGS OR LOOSEN RADIATOR DRAINCOCK WITH SYSTEM HOT AND UNDER PRESSURE. SERIOUS BURNS FROM COOLANT CAN OCCUR.<br /> <p>Drain sufficient coolant to allow thermostat removal(Refer to 7 - COOLING - STANDARD PROCEDURE). Remove accessory drive belt or (Refer to 7 - COOLING/ACCESSORY DRIVE/DRIVE BELTS - REMOVAL).<br /> <p>Add coolant to radiator to bring level to within 6.3 mm (1/4 in) of the top of the thermostat housing.<br /> <br /> CAUTION <p> Avoid overheating. Do not operate engine for an excessive period of time. Open draincock immediately after test to eliminate boil over.<br /> <p>Start engine and accelerate rapidly three times, to approximately 3000 rpm while observing coolant. If internal engine combustion gases are leaking into cooling system, bubbles will appear in coolant. If bubbles do not appear, internal combustion gas leakage is not present.
on Jan 20, 2011 | Subaru Legacy Cars & Trucks
Leaking gas out of gas tank looks like it is missing a plug on the side of tank
I don't know your particular saw, but all fuel tanks are vented. Possibly the vent line or vent fitting has become dislodged and lost.
Sep 13, 2014 | McCulloch Garden
Why is there fuel leaking from a small nipple on the side of our 110cc chinese quad
Engine probably flooded and carb float probably stuck open. Try putting the gas line on reserve and adding an fuel filter to put in btw the gas tank nd carb
Sep 02, 2014 | Garden
Inside the cabin strong gas smell after fill up for approx 50 miles. 2003 Honda Odyssey 85k miles.
do you have the same fuel economy as before or does you gas last less miles than before. if you can smell gas whether the car is running or NOT that means you have a leak in your fuel system if it was not a leak, you would not smell it when not running . first thing is check under vehicle after overnight parking and see if there is fuel on the ground if there is , this will give you a starting point where to look for gas leak. Plugged, dirty or poorly connected fuel injector; Leaking fuel filter or fuel filter connections; Punctured or damaged fuel tank; Loose or poorly connected fuel pump; Gas in gas can in trunk.
Dec 14, 2009 | 2003 Honda Odyssey
How do i access the battery
It appears the battery is under the left side of the gas tank.
First get a 3 mm hex key and remove all the side panel screws and remove the screws that hold the cover around the gas filler cap, and remove the two plastic side panels. After the screws are out the side panels the panels slide forward and will come out. There are two hex screws (size ?) that have to be removed to release the fuel tank. One is under the tank and is accessed from the rear with about a 1 foot extension for the hex bit. The other is on the front rt side and is quite obvious. There is enough fuel hose on the tank that you can simply prop-up the front of the tank with a piece or wood or anything convenient and get access to the battery. I put battery tender leads on my 696. Hardest part is removing all the small screws that hold the side panels and cover for the fuel tank.
Oct 21, 2009 | 2008 Ducati Monster 696
Gas leaking from tank
This sounds like you have a leak at the fuel pump and sender unit, either in the unit mount or in a fuel line. Check under your back seat for an access panel if you have one then remove it and look at the pump and sender mount to see what is leaking, you may have to start the engine to get it to leak as it may only leak under pressure, hope this helps, let me know
Sep 12, 2009 | 1993 Ford Escort 4 Door
Fuel problem
Hi. you may have two issues here. you may want to check the fuel pump o ring for lose or worn fit. i would also do a line check from the tank all the way to the engine. make sure your lines are ok. if all checks out, this may be isolated within the tank hull. replace the fuel tank if a leak is present.
May 21, 2009 | 1987 Alfa Romeo Graduate
Front gas tank leaked when I filled the tank
the top of the tank has an opening where the gas guage sending unit is installed. The gasket can give out and it can leak when the tank is completely full, but won't necessarily show signs of leakage when the tank is partially full.
Requires dropping the tank and changing the gasket... hope this helps.
Apr 20, 2009 | 1997 Ford F250 SuperCab
Gas smell outside of car. unable to see any leaks, car runs fine
Hows your gas milage or do you have any check engine lights come on?Usually if theres no leakage signs its an indication of the evap system leaking.That is recycling of the gas fumes.Its a vacuum system that is now manditory on cars.Thats usually rhe answer when theres no leaking happening.After driving awile open your gas cap,see if you get a vacuum sound when you open it.
Dec 14, 2008 | 2000 Oldsmobile Bravada
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
