Question about HP Photosmart M22 Digital Camera
HP Photosmart M22, won't turn on.
The camera said the batteries were low. I put brand new, just out of the package batteries into the camera. I slid it open just to check to make sure the batteries worked fine and it did...but only for that one time. After I tried to slide it open and turn it on a second time, it didn't. And I tried to tap the front of the camera with a magnetic screwdriver with no outcome (I could be doing that wrong though?) I need help ASAP because this isn't my camera, it's a friend's >.<
    Problem Solver:
  • 8 Answers
There is a magnetic reed switch in front of the power switch and a small permanent piece of magnet just behind the hp logo of the slide door. Try placing a stronger piece of magnet in front of the logo and slide the door again and listen for a click when the reed switch closes. If not sound then the switch could be defective. Replace switch if necessary.
Also make sure you update the M22 camera firmware for power problem before doing any hardware repairs.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ps-32256-2&lc=en&dlc=en&cc=ca&lang=en&os=228&product=437204
If your firmware version number is LESS than 2.02.08 (for example, 2.02.04), then you should install this updated version of firmware.
File name: HP Photosmart M22, won't turn on. - s.gif COL11035en_a.exe, (1/1 , 2.57M)
Enhancements: s.gif
  • Improves battery performance
  • Corrects discharging issue with rechargeable batteries
Posted on Sep 28, 2009
While cleaning out my elderly mothers house I found a Hp Photosmart M22. The memory card and batteries were missing. Otherwise it looks OK. I put in new batteries and a Lexar SDHC 4 GB memory card. It...
The M22 won't work with your 4GB SDHC card. It only works with MMC and SD cards up to 1GB in size. Having said that, if after cleaning the battery contacts and putting in new batteries, it still doesn't work, I'd toss it and get a newer camera. Giving its age and (lack of) capabilities, it just isn't worth repairing.
Mar 19, 2011 | HP Photosmart M22 Digital Camera
My camera wont turn on.
ur lens strip is broken by using in out lens dont use zoom it crecks ur belt. now send for service
Jun 18, 2009 | HP Photosmart M22 Digital Camera
Having problem with my photosmart435digital camera
An electrical spike  from the battery probally you need to RMA it to HP
Oct 14, 2008 | HP Photosmart 435 & HP Photosmart 145...
Batteries
You can try switching over to 2500 mAh Nickel Metal Hydride rechargeable batteries and you will see a difference.
Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries.
May 24, 2008 | HP Photosmart M22 Digital Camera
i still can't solve my problem with my camera.
the screen still displays a red color
Feb 21, 2008 | HP Photosmart M22 Digital Camera
Batteries
Yes I do. We have 2 of these cameras, and have tried every kind of battery out there, incuding rechargables.
This little camera does a lot of things for the price, but it is always hungry. We've only found ONE battery that actually works for it (and takes more than 2-3 pics before giving us error messages), and that is the energizer "e" battery in the silver and BLUE package. They have orange and green packs but make sure you try the BLUE ones.
You might think they are a little pricey (we buy ours at the local WM for around $6 for two, or 419 for eight), but they truly work. Plus, even when they no longer power the camera, there is plenty of juice left in them to power other battery operated items. Our hair trimmers have been running for two months now on a pair of batteries that would no longer power up the camera.
That should solve the battery problems. And, we've also noticed the older the camera gets, the moer likely it is to be extremely picky on the batteries and the DC card!
Dec 12, 2007 | HP Photosmart M22 Digital Camera
Hp photosmart m22 memory card problem
rechargeable batteries voltage actually are lower than normal batteries, but is high when freshly charged or still hot after charging. don't use newly charged or hot battery, wait at least five minutes or let the batt cools down first. some model and brand uses compatible rechargeable batt, it is different from those sold individually which i think you are using. it has special switch activator attachment have you tried to switch back to alkaline? how about formatting the card in pc? try removing then reinserting the card for several times. this will clean the card contact point in camera.
Jan 31, 2007 | HP Photosmart M22 Digital Camera
Hp photosmart m22 wont even turn on dont no why or how to fix
Read 'nightdivers' earlier answer The problem is that there is a small, less than 1 cm rectangular magnet, embedded in the slide cover just to the right side of the "HP" logo and above the "M22" marking, the magnet activates a metallic reed switch on the circuit board when the slide is move to the right to "turn on" the camera and take pictures also exposing the lens. When the slide is moved to the left, the reed switch contacts are off. This would be an easy fix for a camera shop (as long as you tell them what the problem is) and they would not be able to overcharge you with the knowledge you now have... This is a great camera, and would be well worth the fix My addition is: I used a magnetic ended screwdriver and lightly tapped the magnet end over where the badge/logo covers when the slider is opened. hey presto, my camera sprang back into life! reed switch must have just stuck
Dec 19, 2006 | HP Photosmart M22 Digital Camera
HP Photosmart M22 Malfuction
use different memory card, most troubles i always encountered in digicam are caused by memory cards, many cards works in pc but not in digicam. hey tapping side by side always takes away the trouble. [;0)
Jun 21, 2006 | HP Photosmart M22 Digital Camera
HP Photosmart M22 Digital Camera Logo
371 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
